posted by Raditronic on May 19, 2008
the conector p10 have the 10v in pin #1.
1 Other User Has The Same Problem
Comment by kdrummer, posted on Jun 28, 2008
I have a TH-42PD50U with a Power LED flashing ten times when power is turned on. Lost power in a storm and surged when power came back on (TV plugged into a surge protector). TV is located in Belize in Central America and am in need of proper circuit board to replace for repair. Will need to get part(s) in the states and provide to local TV repairman for fix. HELP!
Solution #1
posted on Jul 03, 2008
I just bought a Panasonic TH-42PZ800U and had the same problem. 10
blinks and the TV would not start. Then after some trial and error I
solved the problem!
Here is my (apparent) observation and solution:
I had only one input into the TV, which was my HTPC connected via a DVI-to-HDMI cable plugged into the Panny's HDMI 1 slot. *IF* the HTPC was already on, then the Panny would have the blink of death. *BUT* if the HTPC was off, the Panny booted fine (assuming I cleared the blink of death first by powering off the HTPC, unplugging the TV, and replugging the TV back in with the HTPC still off).
My solution was to move the HDMI cable from slot 1 to slot 3. After making this one change, everything worked as it should. No more 10 blinks of death. I could even leave the HTPC on and turn on the TV last, and it still worked. Tried this 10 times, worked 10 times.
I don't know if this will solve other people's problems, but I hope it at least provides some clues. I wonder if this is a fundamental circuit design flaw on the part of Panasonic, rather than a "bad batch of parts" problem.
Thoughts? Feedback? Send to gcpien at hotmail dotcom
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Panasonic TH-42PD50U 42 in. EDTV
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
Panasonic TH-42PD50U 42 in. EDTV Plasma...
TV panasonic TH42pd50u
TV try to start.Vsus 180v and... Answer This...
hd tv problem
hd tv problem
I have a 42 panasonic hd tv... Answer This...
Remove front cover and replace...
I have on order the entire... Answer This...
tv or cable issue
tv or cable issue
i recently purchased a 50 inch... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
