Question about Mitsubishi WT-42315 42" TV
I have a mitsubishi wt-42315. when i turn it on it shuts down right away. any thoughts?
  • dp840 Sep 20, 2010
    it is showing code 12..
  • dp840 Sep 23, 2010
    ok thanks for the info.. i double checked it and it is code 22. Convergence ic's?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 20, 2010
Testimonial: "Thanks for the help.. Replaced one fuse and both convergence ic's. Problem fixed!!!"
  • SD Tech
    SD Tech Sep 20, 2010
    Unplug set for a minute. Plug back in and try to turn on and when it goes off repeat the check---if before you did check set had been unplugged it will always be 1,2 which is NO ERROR DETECTED.
    1,2 means something has failed but it is not triggering the error code. Not easy to find.
    SD TECH
  • SD Tech
    SD Tech Sep 23, 2010
    it means one of the pico fuses (see photo) that protect them is blown. you need to locate and replace fuse and the chips.
    let me know if questions.
    SD TECH
SOURCE:
I have Mitsubishi wt-42315, I have looked up how to do the self check to determine what may be wrong. It will cut on and a second later it cuts off. I did the self check and it does 2 blink 2 blink. I know...
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Check this site too.
Aug 05, 2012 | Mitsubishi WT-42315 42" TV
Red color shifting and ghosting on my wt-42315
Tv have a problems known as a convergence picture problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board have dead parts like 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must have be replaced to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jul 07, 2011 | Mitsubishi WT-42315 42" TV
Mitsubishi WT-42315 42" TV has a red/Green color seperation
you need to replace the convergence chips, i had this done about a year ago and costs 450.00 usd
good luck
Jan 10, 2009 | Mitsubishi WT-42315 42" TV
Convergence board
YOU WILL NEED PROFESSIONAL HELP THIS IS NOT A DO-IT-YOURSELF JOB. SORRY
Jun 01, 2008 | Mitsubishi WT-42315 42" TV
Mitsybishi WS-65711
Dm module repairs relate more often to Mits Models that end
with # 13 Example = WS-65713....................For info.....
www.chrisandnat.com/projects/blinkingtv/blink.htm ..T.
Typical DM module repair is continuos blinking LED.......
Your symptom is different.........
Apr 04, 2008 | Mitsubishi WT-42315 42" TV
Mitsubishi WT-42313
DM module needs repair = replace bad capacitors ( bulged tops) with four 1000mf / 25v ........T.
Dec 03, 2007 | Mitsubishi WT-42315 42" TV
Red and green lamps look off center
Intermittant convergence alignment issues are quite common.
Either solder the convergence IC pins or better yet , change out
the IC's with first quality OEM spec or upgrade..............T.
May 07, 2007 | Mitsubishi WT-42315 42" TV
Color ghosting on left side
A magnetic field such as would come from a speaker might cause the ghosts but would not stop your set from coming on when it's hot. You may have a horizontal deflection problem such a bad flyback transformer or some other component that gets worse with temperature. You need to have it checked out by a technician. Stargazer
Mar 15, 2007 | Mitsubishi WT-42315 42" TV
Mitsubishi WT-42315 42" TV Logo
634 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
