Question about Bosch Microwave Ovens
I am having a problem installing the cooktop light on my Bosch microwave. It looks as thought the light "blew" and now I can't get the broken lightbulb out of the socket.
  • Bosch Master
  • 9,086 Answers
It's probably attached with hot glue to keep it from getting loose due to heat or vibration.
I would be sure it's unplugged, then use needle-nosed pliers to remove the leftover base from the socket.
Posted on May 22, 2008
Cooktop/nightlight will not turn off. replacement bulb blew when installed.
The problem is on the circuit board, and I regularly repair these by mail.
Feel free to e-Mail me at pupista@gmail.com for details and free advice.
Sep 17, 2016 | LG Over-the-Range Microwave
How do I change the light bulb on KHHC2090
It looks like that answer is on page 33 of your owner's manual.
If for some reason you don't still have yours, you can download it, your installation instructions, and parts lists here.
You can order parts here.
Oct 26, 2012 | KitchenAid KHHC2090S Stainless Steel 1200...
Roper mhe14xm stopped heating. blew a breaker, the microwave comes on, but does not heat. It has a
If this was preceded by failure of the cooktop lights, then you probably need circuit board repair.
Check and see if the cooktop lights and vent fan both work. If not, that's a clue.
Always unplug an oven before removing or inserting bulbls, or there can be a filament short which sends a surge through the controller.
But the first thing I would suggest is a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails and comes up with a "d" error, then you might check the door switches. Help file here.
Once all that is checked, and ruled out, repair or replacement of the circuit board is probably indicated.
Dec 12, 2011 | Microwave Ovens
Hmv9305/01 microwave @ 13months old the magnetron blew, authorized bosch repairman, replaced using bosch magnetron. warranty for 90 days jan of 2011 same problem, why does this happen? should i ditch...
With all due respect, what are you doing to it?
If you use it with nothing in the cavity, that will kill the magnetron otherwise it will last for years and years.
Very unusual and Bosch is a well respected name.
If there is a probem with the oven, Bosch will replace it so take it up with Bosch.
Apr 01, 2011 | Bosch HMV9305 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Light under sharp built in micro wave oven will not shut off
Sorry, but your subject line was too long and it got cut off.
I'm assuming your cooktop light blew and even though you installed a new one, it still won't come on?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 12, 2009 | Sharp R-1501 Microwave Oven
Remove cooktop bulb
First of all, be sure to unplug the microwave before removing or installing the bulbs.
Second, the bulbs may be tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
I would suggest that you use a hair dryer to heat up the area where the bulb and base (socket) meet. But look out for any softening of the socket.
Once you have replaced the bulbs, don;t be surprised if they either don't come on or won't shut off, or if you have such a problem with the hood vent exhaust fan.
We see (and repair) this control board problem a lot.
William E. Miller
prototech@usa.net
Dec 22, 2008 | Whirlpool MH1170XS Microwave Oven
Purchased Bosch Combination Oven/Microwave Ref: E No: HBC84K520B FD NO: 86070009 When press start on microwave it runs then bleeps and shows error message "E9" and stops.
Not sure on Bosch, since it's a non-US brand, but that may be a bad door switch.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Otherwise, you can get Bosch support here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 21, 2008 | Bosch Microwave Ovens
Cooktop light quit working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
William E. Miller, AS-EET
prototech@usa.net
Apr 20, 2008 | Whirlpool MH1140XM Microwave Oven
Microwave Ovens Logo
128 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
