Question about Gateway m1300-3004372 Tablet PC
Dashboard dasboard.exe producing the following error: LCD Brightness control oper failed! Hybernate, screen rotate, etc don''t work!!! Thanks!
  • halbertoit May 19, 2008
    I do not have the driver
  • 3,037 Answers
Try using device manager to install the driver instead.
Since I am not familiar with this error, I looked up a little info and found another guy that got it working by doing this. You can check out the information on his problem at the following link.
HERE IS THE LINK
Let me know if you need further questions answered or if this doesn't work
Posted on May 19, 2008
    President:
  • 2,712 Answers
You may need to do a FULL restoration to factory settings with the recovery disk.
  • Gateway Master
  • 13,433 Answers
Hybernation is probably turned off.
to turn it on
start -> control panel -> power settings -> hybernation tab
enable hybernation.
I'd recommend you reinstall the driver software for your dashboard screen / video card.
Do you have the cds or should I get you a download?
How do I disable the auto rotate?
Windows, Android, iOS all below. Number 1 tip, MAKE and MODEL always on Fixya :>)
Press the Windows ( ) key + C, or swipe in from the right edge of the screen to open your Charms. Tap 'Settings' and tap 'Screen' in the bottom of the bar. Tap the little square icon above the brightness-slider to enable/disable auto-rotate.
Jul 22, 2015
How can I enable/disable the auto-rotate function in Windows?
https://us.answers.acer.com/.../how-can-i-enable%2Fdisable-the-auto-rotate-function-in-...
How to Enable and Disable Auto Rotate on Android - Technology Hint
https://www.technologyhint.com > Android
  1. Cached
Nov 12, 2017 - Android has the auto rotate screen option which automatically rotates your device's screen when you move your device between landscape and portrait mode. This feature is a useful one. But, not for all. If you don't want this option turned on, then you can disable this feature. In this post, we will see the ...
How to Lock Orientation to Stop Screen Rotation in iOS 10, iOS 9, iOS 8
osxdaily.com/2013/10/14/lock-orientation-ios-7-screen-rotation/
  1. Cached
  2. Similar
Oct 14, 2013 - Yes, you can still lock the screen orientation in iOS 10, iOS 9, iOS 8 and iOS 7 to prevent the display from rotating itself when an iPad, iPhone, or iPod touch has been physically turned onto its side. The orientation lock is now in a quicker access location contained within Control Center, making it much faster ...
Mar 29, 2018 | Tablets & eReaders
How to get my tablet to start rotating again. It is set to auto rotate but it won't stop working.
This varies by operating system which is why it is a good idea to post the brand, model, and operating system with a query.
For a Samsung Galaxy 10.1:
Type apps is the upper right corner. Then tap Settings from the all tab. Then in the left menu, tap screen. Then, tap auto rotate
For the Inspiron Dell 2-in-1 with Windows 10:
Go to Control Panel> Display>Change Display Settings and then make sure that the "Allow the screen to auto-rotate" is selected. Or try the following: Place the tablet into Pad/Tablet mode.
Click the Start Start menu and select Settings. Click System.
Click Display. Scroll down and toggle Lock rotation of this display to ON.
Or this might help:
Click the Start Start menu and select Settings. Scroll down and toggle Lock rotation of this display to OFF.
Nov 26, 2017 | Tablets & eReaders
How do I adjust the brightness on my Samsung Tab 4?
Tap Settings>Display>General>Brightness, adjust to desired brightness, left or right. Alternatively, from your home page, drag your finger from the top edge of the table screen downward to expose several power button shortcuts (Wifi, GPS, Mute, etc), including the brightness scale, adjust the brightness left or right and/or select the auto[brightness] checkbox.
Sep 21, 2014 | Samsung Galaxy Tab 4 8.0 3G T331 16GB GSM...
How do I make my kindle fire screen brighter?
Adjusting Screen Brightness The screen on the Kindle Fire uses more power than anything else, and the brighter the screen, the more battery power it uses. To increase battery life, you can lower the brightness of the display.
Unlock the rest of this book. Swipe the status bar down to open the Settings drawer.
Unlock the rest of this book. Tap Brightness.
Unlock the rest of this book. Slide the brightness control to the right to increase brightness and to the left to decrease brightness.
Jun 21, 2014 | Tablets & eReaders
Lcd hard to see
Go to setting - brightness and wallpaper and rank up the screen brightness. :)
Dec 30, 2013 | Apple iPad Mini
How to fix not working touchscreen? Do i have to replace it?
The Samsung Q1 is a hybrid, ultra-mobile, touch-screen device that is basically a very small tablet PC. It features a 7-inch screen, weighs a mere 1.7 lbs., features a Windows operating system, doesn't have a built-in keyboard, and comes in a variety of configurations. The Samsung Q1 doesn't offer outstanding battery life, but you can make some moves to boost your computing time.
Dim the Screen
Dim the screen brightness. Four programmable application-launch buttons occupy the right edge of the Q1. One of these, the menu button, calls up frequently-used controls, including screen brightness. Reduce the screen brightness as much as you can, as it's one of the best ways to extend battery life.
Close Power-hogging Apps
Close applications and browser windows when you're done with them. Too many open programs drain the battery. Beware power-hogging apps. Watching a video or listening to music on your Q1 drains your battery life much faster than just using Microsoft Word or checking email. Turn off the Wi-fi networking when not in use. The built-in Wi-fi searches for a network when you're not connected, which drains battery life.
Properly Caring for and Feeding a Battery
Unplug the Samsung Q1 after the battery is fully charged. Leaving your Q1 plugged in 24/7 leads to some discharge from the battery. Consider buying a bigger battery. A 3-cell battery comes with most configurations of the Q1, but you can also buy a 6-cell battery to double the battery life.
Room Temperature is Best
Don't expose the Q1 to harsh conditions. Keeping the device in a blazing hot car in direct sunlight harms your battery life. If you use your Q1 in conditions above 95 degrees Fahrenheit, you can permanently damage the battery. Cold conditions don't harm the battery in the same way, but if you leave the Q1 in the cold, let it warm to room temperature before you use it.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Samsung Q1 Tablet PC
I have a Toshiba Portege 3500 with rotating LCD screen, my problem is that I can not rotate the wiew of the screen. The settings were changed, and now I can not rotate the view again. Thanks for your...
Do you have Windows XP with servicepack 3 installed? If so then there is a known problem with the screen driver and XP sp3. Go bakc to SP2 and reinstall de display drivers this should clear the problem.
If anyone has working tident drivers for XP SP3 I would be greatfull!!
Aug 04, 2010 | Toshiba Portege 3500 Tablet PC
Disable TC4400 auto rotate
First in Control Panel -> Tablet and Pen Settings, select Display Tab, then click on Change button next to Sequence. I set 1 as Landscape - Primary, then 2-4 as None.
Second, Go to Control Panel -> HP Quick Launch Buttons -> select Preferences tab -> uncheck the checkbox that says, "Enable Automatic Mode Change"
This worked for me!
Mar 08, 2010 | Compaq tc4400 Tablet PC
I can't logon my toshiba portege m400 - s5032x a error message shows up saying Isass.exe application error the application failed to initialize properly (0xc0000005). Click on ok to terminate the...
Your system is infected by Sasser worm.The Sasser worm infects machines via network connections. It can attack entire networks of computers or one single computer connected to the Internet. The worm exploits a known windows vulnerability that is easily patched, however few systems seem to have this patch installed. It attacks Windows 2000 and Windows XP machines along with Windows NT and Windows Server 2003.
The patch from Microsoft known as the MS04-011 Security Update fixes the following vulnerabilities:
LSASS Vulnerability
LDAP Vulnerability
PCT Vulnerability
Winlogon Vulnerability
Metafile Vulnerability
Help and Support Center Vulnerability
Utility Manager Vulnerability
Windows Management Vulnerability
Local Descriptor Table Vulnerability
H.323 Vulnerability
Virtual DOS Machine Vulnerability
Negotiate SSP Vulnerability
SSL Vulnerability
ASN.1 “Double-Free” Vulnerability
Download the Windows patches for this vulnerability.Here is the link below:
http://www.microsoft.com/technet/security/bulletin/ms04-011.mspx
How Can I Remove the Sasser worm?
Follow these steps in removing the Sasser worm.
1) Disconnect your computer from the local area network or Internet
2) Terminate the running program
Open the Windows Task Manager by either pressing CTRL+ALT+DEL, selecting the Processes tab or selecting Task Manager and then the process tab on WinNT/2000/XP machines.
Locate one of the following programs (depending on variation), click on it and End Task or End Process
avserve.exe
avserve2.exe
skynetave.exe
any process running with the "_up.exe" suffix
Close Task Manager
3) Activate the Windows XP Firewall (if running Windows XP) or another firewall to prevent the worm from shutting your system down while downloading the patches. To activate the Windows XP firewall, follow these steps.
Click on Start, Control Panel
Double-click on Networking and Internet Connections, then click on Network Connnections
Right-click on the connection you use to access the Internet and choose Properties
Click on the Advanced Tab and check the box
"Protect my computer and network by limiting or preventing access to this computer from the Internet"
Click OK and close out of the Network and Control Panel
4) Remove the Registry entries
Click on Start, Run, Regedit
In the left panel go to
HKEY_LOCAL_MACHINE>Software>Microsoft>Windows>Current Version>Run
In the right panel, right-click and delete the following entry
"avserve.exe"="%Windir%\avserve.exe"
"avserve2.exe"="%Windir%\avserve2.exe"
"skynetave.exe"= "%Windows%\skynetave.exe"
Close the Registry Editor
5) Delete the infected files (for Windows ME and XP remember to turn off System Restore before searching for and deleting these files to remove infected backed up files as well)
Click Start, point to Find or Search, and then click Files or Folders.
Make sure that "Look in" is set to (C:\WINDOWS).
In the "Named" or "Search for..." box, type, or copy and paste, the file names:
avserve.exe
avserve2.exe
skynetave.exe
C:\win2.log
Click Find Now or Search Now.
Delete the displayed files.
Empty the Recycle bin
6) Reboot the computer and update your antivirus software, and run a thorough virus scan using your favorite antivirus program.
For Automatic Removal of Sasser, download the Symantec removal tool, you'll still need to download the patches above and install them, however this removal tool will stop the Sasser worm from running, remove the items in the registry, and delete the infected files.
Dec 27, 2009 | Toshiba Portege M400-S5032X Tablet PC
Wifi fails to resume
Go to Start/Control Panel/Network and Sharing/
then click on View Status, then Diagnose. That usually restarts your wifi so you can be back online without restarting Vista.
May 13, 2008 | Compaq 2710p Tablet PC
Gateway m1300-3004372 Tablet PC Logo
116 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
