Question about Emerson EWC1304 13 in. TV/VCR Combo
Tape stop the tape and it ejectson its own not letting go of the tape,some times you have to cut it loose but always wrinkles the tape,and then the power shuts off after a couple of seconds or so.tried sevral new cassets,not the problem.I think it is a modle defect because ive had 4 of them with the same problem,took 2 back to store but stuck with 2 of them now sence you cant get them at the store any more.ALL 4 units had/have the same trouble.....tired of messing my security tapes.....thanks
  • 1 more comment
  • ericmol2 May 19, 2008
    why would 4 units do this when fairly new?
    they came from 3 different walmarts 1 in NE-Ga 1 in central Ga and 2 in south Ga where i live..at they play fine untill you hit stop..I you keep working with the thing over a short period of time it will even get worse.to the point when you slide a tape in it will show eject on the screen(eat the tape sometimes)and then power off..you have to turn it on ade eject the tape quic(or it will power off)and then you have just a tv to watch.They were bought pretty close together when the new style tv`s were taking over and these were getting scarce in the store,i even tried to buy a display set one time but couldnt.
  • ericmol2 May 30, 2008
    have you found out anything?
  • 4,234 Answers
This is a simple fix for any shop that has done these before. You need new belts/idlers and a ngeneral cleaning and alignment. Figure on $75 or so for each for parts and labor.
Dan
Posted on May 19, 2008
  • ABRsvcs May 19, 2008
    If these are brand new, this should not be happening. I misunderstood your statements. The problem is that the takeup side is failing. This causes the tape to accumulate inside and get caught when the cassette ejects. If the transport is the one I think that it is, there is a small rubber bumper that controls the position of a sliding cam assembly. These could be defective. If you have received a number of these from the same place, it may be a bad run. I'll look up that model and try to get you more details.
    Dan
After tape starts to play, why is it ejected and player shuts down?
The tape may be defective in some way such as wrinkled or slack in the cassette. If other tapes are handled the same way, the fault probably is in the player mechanism.
Jan 05, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
MY DRYER DOES NOT STOP AT THE END OF THE CYCLE, THE BELL GOES OFF BUT DOES NOT STOP
if you have selected wrinkle release thats normal it will keep on going on just air not to let the clothing sit and get wrinkled
Jan 20, 2015 | Samsung DV431AE 7.4 cu. ft. Electric Steam...
VC500 - Arc Soft Biz capturing problems
Using old tapes is the wrong way to go. Eventhough there is an rease head in the VCR, there will always be some residual information left behind that affects the new recording. Older tape also has a tendency to flake off and plug a video head. A tape with a wrinkled edge will confuse the recorder speed sensor and try to change speeds too.
Dec 23, 2013 | Diamond Multimedia ( VC500) Video Capture
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
Error 02 - 574
Main code 2X : Mechanism control system error
574 Failed to detect the T reel FG during search.
This means the take up reel stopped rotating during forward search. It shut down assuming tape was spooling loose into mechanism. Could be just a faulty cassette tape. A common problem is also when labels have been placed in the wrong places on the cassettes, stopping the lid from opening fully and stopping the reel reaching the reel motor drive.Manually eject the tape and try another tape. If the fault continues, have a look for something in the way under the cassette such as post it notes, paper clips, torn labels etc.
Have you had the unit serviced since you got it?
Could be time to get it to a service centre for help.
Aug 06, 2012 | Sony HVR-1500 HDV VCR
Dryer cuts on run a minute starts buzzing loudly and shuts off then a little while later starts by its self
DOES THIS DRYER HAVE A WRINKLE GUARD CYCLE OR SWITCH THEN THIS IS NORMAL ASLONG YOUR IN A WRINKLE GUARD CYCLE ON TIMER OR WRINKLE GUARD SWITCH IS ON
Jan 26, 2011 | KitchenAid Dryers
Truck looses power and shuts down while driving
did you check fuel filter ?? and or fuel pressure
Jan 31, 2010 | 1999 Ford F150 Regular Cab
Eats tapes
this use to occur to myself also, then i had switched tapes....now i only use maxell 90 min (or sony) all 110 / 120 min tapes use to jam up....as of right now this will continue to occur to you because the tape is now wrinkle and not smooth like it suppose to be...plus every two weeks you should take a q-tip (wet it no alcohol) to to clean your rec / play head and the black wheel inside the deck....i know a little late...but i this helpful
May 05, 2007 | Jensen CR220X Cassette Player
Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Jan 27, 2007 | Sony SLV-940HF VCR
Emerson EWC1304 13 in. TV/VCR Combo Logo
42 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
