Question about Xante ScreenWriter (Refurbished) Laser Printer
Platemaker 4 (image quality problem)
In all the non-image area of print, I can see a grayed high frequency banding ( regular spaced), I try with another half-life print cartridge and cleaning BTR but I can´t fix it, Can you help me?
Thanks
Jose mejia
  • 3,037 Answers
Try cleaning the contacts within the printer between the cartridge and the printer itself.
Also try resetting the printer by disconnecting it for 5 minutes and then also change your print settings back to default or just delete the driver and try reloading it and this should set it to default.
Let me know how this works out and we can try further options
Posted on May 19, 2008
  • Xante Master
  • 13,433 Answers
Read this epson page
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_2.htm
There might be something of use for you.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
Screen Setup
Do you mean for screen printing? How many colors? You need to assign specific LPI's, angles and dot type depending what you are trying to print. Your art also might need to be set up better. Can you send link to image and print?
Apr 01, 2014 | Xante PLATEMAKER 4 Laser Printer
Myriad 2 polyester plates constant toning problems, tried different fountain solutions added varnish to the inks need your expert advise
Darrellf674
Did yor even find a resolution to this problem? I am having a similar issue. I have ink transferring from the non image area of the plate to the blanket. I can't see the toning on the plate but I sure do see the ink on the blanket.
May 05, 2011 | Xante PLATEMAKER 4 Laser Printer
Diffenent tint to 4:3 area during full screen projection.
di you try to conv. it and if that don,t work you need to see a tv repear
shop
Dec 07, 2009 | Toshiba 50H82 50" Rear Projection...
I want to unblock my uniden bct7 scanner, Can anybody tell me how
The BCT-7 covers popular frequency bands, skipping things like television signals, non-voice (data) bands, and banned (cellular) bands. It cannot be modified to receive other frequencies. Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BCT7om.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Apr 04, 2009 | Uniden BCT7 Base Scanner
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
When printed from a scanned image vertical bands appear
Well, now, jannyloubran,
I hope that I understand your question: are you saying that there are vertical bands when an image is scanned, and then printed? In other words, if you download, say, a picture from your digital camera and print it, no bands: but, if you scan a photograph, then print the scanned image, you get the bands?
Going on that assumption, I would guess one of two things is happening, and possibly both:
  1. The resolution (usually "dpi" in America) is set too low on your scanner to get a very good scan, and so the print is poor. To scan a picture, you really should set the resolution as high as your equipment will allow and your hard drive has space for (the higher the resolution, the more space the file created from the scan takes). Without getting too technical and getting into optical vs. interpolated resolutions, 1200 x 1200 is usually an adequate starting point that will give a decent image (hopefully sans bands) without taking up gigabytes of storage space per scanned photo. You need to open the scanning software that came with your printer and set the resolution higher. If you can't figure out how to do that, open the help file that came with it or go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13800. From here, you can search their FAQ, ask a question from their knowledge base, send tech support an email, or get a phone number for support.
  2. If your scanner is an older one (you didn't specify), then it may be either worn out (unlikely) or simply not able to support a high-enough resolution for the quality we have come to expect.
Now, if it turns out that I have been having a bad dream and none of the above applies, please repost with more information as to exactly what you have to do to replicate the problem, including what, exactly, you mean by "bands" (black and white bands, bands of fuzzy focus, bands of off colors, wide bands, narrow bands, bands all the way from top to bottom or just halfway, or what?). Also, have you changed anything else between printing from the computer and trying to print the scanned image, such as new cartridges or aligning or cleaning the printhead? I know it's a pain to spell it all out, but sometimes that's the only way we geeks can figure out how to help—and, I hope this helps!
Ken
Feb 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Image quality
Not my area of expertise,but maybe a change
in ink cartridge or material is in order
May 17, 2008 | Xante PLATEMAKER 4 Laser Printer
Xante ScreenWriter (Refurbished) Laser Printer Logo
163 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
