Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Refridgerator Issue Did you ever find out what was causing the clicking and power drain on your refridgerator? I think mine is doing the same thing.
  • 828 Answers
Sounds like a compressor trying to start and is not. Check at the compressor for a hum then a click. This is a sign that the compressor has failed. If you had a power outage try unplugging it for a period of time and then plug it back in.
Posted on May 26, 2008
The ice maker in my Samsung French door refridgerator keeps getting frozen up. Help
hi Delunn.
this could be a couple of things wring.
so i think it best you go to this link and see if it helps you out.
ice maker in my Samsung French door refridgerator keeps getting frozen up...
Dec 02, 2017 | Samsung Refrigerators
Waht makes a Dometic 1402 work normal on electric but the refridgerator warms up when on gas? Freezer warms up slightly but refridgerator 10 to 15 degrees?
Dometic had several recalls for that problem, faulty thermostat I believe. Mine does the same thing, but I haven't taken it out to replace the thermostat / thermocoupler.
Aug 20, 2014 | Dometic Refrigerators
Water leaking inside refridgerator KENMOORE 60187000 DRIP PAN IS DRY
Hello Patrick,
The leak is caused by a blocked drain for the defrost. It is a fairly common thing so common in fact i have written this tip explaining how to clear a frozen drain for the defrost.
http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Oct 28, 2011 | Refrigerators
Our refrigerator has started to leak water outside the refrigerator in the front. What could be causing this?
from inside refridgerator, or from below?
could be your condensation drain pan or the tube from the refridgerator to the condensate drain pan is stopped up. Have to take lower access panel off back of unit.If it has an icemaker, the water line could be leaking.
Mar 14, 2010 | Whirlpool 18.2 cu. ft. Top Freezer...
Why do i have water in my refridgerator
Air contains water particles and it will condense to form solid ic, you have to defrost your refridgerator on a regular basis and have to watch the water is drained up to the maximum extent
Dec 17, 2009 | Kenmore Refrigerators
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaking inside refridgerator
not shure as to the design of that brand, but it is usually caused from a bloked up drain
Oct 25, 2008 | GALAXY Microsystems 63702 Top Freezer...
Frigidaire refridgerator Model #FRT16CRH, how to clean freezer insulation
that part is the hart of the unit and more trouble than you want to get into. i do not suggest that you try and take it apart, you could really mess things up, would be very unlikely that anything got between there anyway
May 16, 2008 | Frigidaire FRT17G4B Top Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
50 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
