Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell 7920 ProHeat Problems--No solution spray
My unit is only cleaning with water at this point. It does not spray the cleaning solution. I made sure the tube is not clogged and there is plenty of solution in the small tank. Any idea as to why this is happening and what we can do to fix it?? Thanks so much!
    President:
  • 1,673 Answers
Is the smart mix valve turning and stopping where is is supposed to, if it turns all of the way around, then it is broken inside the top cover. Try replacing the smart mix bottle insert and cap asm part #2101795 . Make sure that the rubber gasket is on the valeve asm. at thebottom of the smart mix bottle. If not, it has to be on the valve.
Posted on May 20, 2008
Bissell proheat2 Wont spray water, or the suction isn't picking up.
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Nov 20, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro heat not spraying water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
Sep 06, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell, ProHeat, ProTech won't spray water.
heatman101
895r
Jul 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
WATER PUMP
heatman101
eyhj
May 08, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Won't spray wate rwhen you press trigger.
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
Bissell 7920 Belt and Manual
Dec 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
178 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
