RCA F20518WN 19" tv
I have an RCA F20518WN 19" tv and the first time i used it i plugged it up with my direct tv and autoprogramed it and it stoped on chan 3 and worked fine but when it was cut off i turned it on and autoprogramed it and it stoped on chan 2 and dosent work i have even got a universal remote to turn the channels and turned it to channel 3 but its in gray and black dots and wont come on same problem with my xbox plugged up PLZ help
  • 2,712 Answers
Sorry, I am not sure..this is not really my area of expertise. You would probably want to get in touch with Bestdarngood
He'd probably be able to assist you better. Please do not rate this post, as I was unable to provide you with a solution..
Posted on May 19, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
Matching older RCA TV to Sony Universal Remote - Need RMA code
go please to or www.
God bless you
Jul 02, 2012 | Televison & Video
I have an old RCA F2763OSF. I don't have the original remote as I use a Verizon box. I can't get the TV on channel 3. It jumps from 2 to 4. There was brief power outage. How do I get back to channel 3
siest way is to be sure that there is a signal for channel 3 (cable box) and then engage the autoprogram feature. You should be able to do this from the front panel.Once the autoprogram is complete, channel 3 should again be available.
Feb 20, 2009 | RCA Televison & Video
Cannot get tv to synchronzie with hd converter box
Jan 22, 2009 | RCA Televison & Video
Jvc tv
go to menu and scroll down to autoprogram-with cable box turned on- and run autoprogram; it will pick up ch#3.
Another option is to use video inputs and take video and audio using RCA connectors.
Jun 11, 2008 | Televison & Video
Parental lock
Child Lock
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Trying to program my DIrect TV remote to work my ILO TV
i have two tvs 1 is an Ilo and the other is a Sylvania. the code for sylvania works for both tvs on the Direct Tv Remote Hope this all helps and here is the code. 10171, there are also two other codes for this tv and they are 10054, and 10030. Have a good day and happy watching.
Nov 10, 2007 | One For All URC-3021 Remote Control
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Lost channels 2 through 52
I think the low band (Channel 2-6)in your tuner is not working. This could be in the tuner itself or in the band switching circuits. Possibly she deleted the low channels or locked them out. Stargazer
Jun 14, 2007 | RCA F32632SB 32" TV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
