Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Freezer fan does not cut-off.
Freezer fans does not cut-off, ice does not form. Please HELP.
tjbrana@gmail.com
Replace the thermostate &try,it should solve the problem.
Posted on May 19, 2008
FRIDGE DOES NOT KEEP COLD AND FREEZER OVER FREEZES? NOT FIND THE MANUAL PLEASE HELP. THERMASTAT? WHERE IS IT? WANNABEHERD@OUTLOOK.COM
Don't understand 'over freezes'. If, by that, you mean that frost is forming on the walls and/or bottom of the freezer section while the refrigerated section does not maintain temperature, odds are that your fan in the freezer is not spinning. This is usually caused by one or more of three different things: 1) motor failed 2) defrost heater/safety/clock failed or 3) drain from freezer is plugged and ice is building up over the fan.
Apr 22, 2015 | Refrigerators
We have a e381t model refridgerator/freezer. there is a rattle/scraping noises coming from the fan in the freezer part. There is ice behind the protective sheet that separate the fan from the main area. Is...
If there is noise of the fan rubbing with the frost build up on the freezer then it is confirmed that the defrost timer is faulty. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 17, 2011 | Fisher and Paykel Refrigerators
Freezer appears to be working, as ice forms in tray. No cooling in refrigerator. Fan in back of freezer is not working.However when you touch the fan blade it will turn for a second or two.
fAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 14, 2011 | Whirlpool Refrigerators
Hey there, I have a Westpoint NOFROST De Luxe Tropical frige, model # WRK 297.1. The freezer section is forming ice and the circulation fan is making alot of noise due to ice being formed behind the back...
I believe your problem is the defroster circuit . There are only three components on most refrigerators unless you have something real special . Kidding . They are as follows : defrost timer , heating element , and defrost cut out switch . The defrost timer cycles the refrigerator out of normal operation and into defrost mode once every six to eight hours depending on the unit . When in this mode everything shuts off , compressor , circulation fan , and condenser fan is so equipped . To eliminate the circulation fan , you'll have to keep an eye on your refrigerator checking in every half hour or so for six hours to eight hours and see if it stops working . If it does , then we know the timer is working correctly and the problem will be the heating element or cutout switch . The heating element is checked with an ohm meter. Usually they burn out when they go bad and you will read infinite resistance. The defrost cutout switch should read 0-1 ohms when the freezer temperature is 40° F or lower. If the heating element checks good , in other words it shows to have resistance usually between 30 and 100 ohms, replace the cutout switch . If the circulation fan never shuts off and the unit continues to run without shutting down after a six or eight hour Time cycle , replace the defrost timer . Good luck
Feb 22, 2011 | Refrigerators
Ice forming on copper pipe coming from compressor
Hi, It is not uncommon for the suction line on a unit to have ice on it when cooling. This means that where the ice starts forming on the line, there is liquid freon there. But, if it continues to get worse, would indicate a problem as you don't want liquid freon to enter the compressor as it will burn out the valves, or slug it as we say. Icing of this line can be from a few things. Low on freon will cause it to ice up. The freezer fan/evaporator fan motor not working. The freezer iced over real bad. An over charged system will do this, but you haven't had to charge it. Check the fan I mentioned and keep an eye on this line and monitor the units temperature. If you start to loose your cooling then we need to go from there. I can't prevent it from forming ice unless I was on site to install my service gauges to check the internal condition. Please keep me posted though. If the freezer fan is not running, this would be the problem and would need to be replaced. If you had excess to a volt meter and it wasn't running, you could check power to this motor. Let me know if it is not running and check the temperatures closely.
Good Luck,
Shastalaker7
Mar 09, 2010 | Freezers
Ice melting and frost forming on freezer side, funny sound coming from freezer side. No condensation in back of fridge. Help for a new home owner.
check that your flapper on the ice shut through the freezer door is fully closed,
make sure there is no ice forming around your evaporator fan, thats the fan in the freezer, if that gets glogged with ice and is forced to stop, it could blow your entire machine control......
the frost in the freezer leads me to believe you may have a defrost issue
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice is forming in my Freezer and the roof is forming drops
Unplug it and let it defrost. wile it is defrosting pull the botum front cover off and vacum out all of the acumulated lint off the tub on the bottum. after about 2 -3 hours plug it back in and listen for the fan running on the inside if you feel air coming out of the vents then you should be OK. If no fan replace it.
Sep 11, 2009 | Kelvinator 24 in. MDB421RF Built-in...
The fridge part of the fridge freezer has a coating of ice forming at the back and it feels warm behind bottom right veggie tray
Sounds like the freezer/refrigerator circulating fan is starting to wear out, When the motor for this fan starts to wear out it does not supply enough circulation for the freezer and the refrigerator. The minimum cost to repair/replace this fan is around $300.00. The immediate solution is to unplug you unit for about four hours allowing the ice that has formed around this fan to melt. Or use a hair dryer to melt the ice, but be very careful not to melt the plastic.
Jul 11, 2009 | Refrigerators
Fan in freezer - evaporator fan?
HI. thanks for the question. yes the fan in the freezer must be replaced.and also the drain tube in the freezer, is clogged. cut power to the fridge. remove back panel . replace the fan motor . also clean ice build up. clean drain tube, from freezer to the drain tray, at the back, near the compressor. thanks the appliance doc. please rate my answer. thanks
Oct 07, 2008 | GE GTS22WCP Top Freezer Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
80 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
