Question about Canon Office Equipment & Supplies
Canon i865 Printer produces green tinge on photos. Genuine Canon ink tanks are installed.
    Problem Solver:
  • 19 Answers
Here is a web-site Canon has on this issue, you can select your operating system and manually adjust the tint, or you can perform deep head cleaning.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9387
-Hope this helps.
Posted on May 19, 2008
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
Waste ink absorber full
CANON WASTE TANK RESET CODES
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
8. Your printer should respond as normal.
Sep 04, 2008 | Canon Office Equipment & Supplies
I am printing exterior photos of a buildiing on regular paper for test only. The color is printing out with a green tinge. What is happening?
Not using genuine HP cartridges could be one reason. Low ink cartridges could cause not enough ink to be used to make a certain shade of gray or black and thus causing the green tinge. Also if you are selecting photo quality printing then you need to use photo paper. The printer drivers tell the printer different commands depending on what kind of paper you tell it you are using. Good luck!
Mar 09, 2011 | HP Deskjet 3745 Inkjet Color Printer
Despite new cartridges I am getting a weird colour balance. Too much of a red tinge..almost as if the cyan cartridge is empty. I have utilised the cleaning and deep cleaning options several times but this...
I was getting green tinges for a long time and even though I cleaned everything it still happened. I had also used non genuine cartridges.
Eventually I took the cartridges out and gently wiped clean where the ink actually goes in and this worked. I have always been told that non genuine cartridges will ruin you printer?????? I now have all genuine back in and it works with no tinges. Was is the cartridges that clogged it - I don't know. But now that I know how to clean I will propably use the cheaper ones.
Sep 06, 2010 | Canon PIXMA MP610 InkJet Printer
Printer is saying more then one ink tanks of the same colour is installed. Yellow. Then it is saying it isn't recognising the yellow ink
Do you have all Genuine Canon Ink Jet Cartridges?
If you don't then that could be the problem.
Otherwise, if you do, then I would try another yellow ink jet cartridge from Canon.
Aug 20, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
I have a PIXMA 960. changed all the cartridges, did deep clean, alignment etc and photos still coming out wrong - orange tinge to shadow areas, blue eyes washed out....
may be problem with waste ink tank....
When waste ink tank full it gives this kind of problem.replace the waste ink tank..or visit nearest canon dealers or service provider.. they solve u r problem by replacing waste ink tank.
if it helps
Rate me!
Jun 25, 2009 | Canon PIXMA MP960 All-In-One InkJet...
After a month or two of disuse my i860 6BK cartridge will not print. On a nozzle alignment printout the 6bk color bar below the 6y bar is absent. The square labeled "F" in the lower part of the printout is...
Hi
You can try this I found.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 03, 2009 | Canon i860 InkJet Photo Printer
S9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
1. Turn off printer
Nov 02, 2008 | Canon i950 InkJet Photo Printer
Colour photo printing has a green tinge
This could be one of many things.
Monitor Calibration to Printer.
Camera green Bias
And good many more
The thing is not to print direct from camera , but to use an image editor to colour correct.
A free simple one is Googles free Picasa.
Otherwise there are many more some free a lot to be paid for.
As always there is a learning curve.
Sep 09, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i865 printer
Hi! I've got same problem. Canon userguide says that 5 flashes means the print head is not installed/not properly installed, or it is defective.Not yet sorted problem out - new print-heads are expensive!
Feb 12, 2008 | Canon i860 InkJet Photo Printer
149 people viewed this question
old marine
old marine
