Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Power light flashes 3 times
I own a 52 inch rca hdtv model # d52w20 When turning the tv on the power light would flash 3 times and the tv would not come on. After many attempts the tv would work that lasted for about 3 weeks now it just flashes and does not come on. This happened once before and the tech replaced the power transistor and fly back. I ordered a fly back and will try that any other advice would help.
Thank you in advance, this is chriskc and i have this problem with my Sony Trinitron 27 in tv light flashes 3 times and won't power on either . Is there a fuse inside the case of the tv ? I notice there isn't any resent button on it . Can't find one anyway thank you for your asistance
  • Chuck Foltz
    Chuck Foltz May 31, 2008
    Unable to get unit to come on. The light flashes. I followed the diagnostic to shut down power and wait before hooking back up and trying to start again. It would not come up. The set had been taking a little longer over a period of time to finally start up until the day came that it refused to start at all.
    If it is a "flyback transformer" as described, how does one determine the specific one to order and install, or is a better idea to have a tech do the repair?
  • 58 Answers
More than likely the sony has a bad flyback
It is available from
www.electronix.com
Thanks Guy
Posted on May 27, 2008
I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power...
On Deflection board CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad their is 2 more caps in same circuit replace them also cp114 cp120 220uf 35v also resolder all pins on FBT flyback Transfomer
Nov 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light flashes
Same thing here....RCA tells me to count the times the light flashes as it apparently is set to "tell" you what the problem is.......3 to 5 flashes means your lamp is messed up.....they are over $300 to replace!
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
142 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
