Question about Toshiba Televison & Video
Our newly purchased Toshiba - REGZA 42" 1080p Flat-Panel LCD HDTV has a fuzzy "snowy" picture. Direct TV is our satelite provider.
    President:
  • 2,712 Answers
First check if this happens in other external video source as well, like DVD/CD/VCR, etc. If it does, get the set replaced under warranty.
If it happens only with the Direct TV setup, try unplugging the set top box from both power supply and TV. Wait about a minute and reconnect. If the problem is rectified, the issue is with the setop box. Call Direct TV in this case.
Posted on May 19, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
I have picture but no sound when connected thru hdmi using a panasonic blue ray Dvd player. It is working fine with my 42 inches sharp lcd.
Be sure you are not trying to use 1080p/60 from your Blu-Ray player to your Toshiba. You should connect the player to the Sharp, then set the output to 1080i... then move it over to the Toshiba.
Mar 14, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Direct TV setup indicates my TV is not 1080P but
the only input on the Mitsubishi that is 1080p capable is the rf input.
Sep 19, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Snowy picture
.u need to replace the tuner of ur tv set...its a technical work better call service technician
Jun 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
HI i have a 42" Hitachi HDTV 1080p (LCD)
Most newer Digital TV's don't display Analog signal very well. Often worse then an Analog TV. This is normal to a degree. If your Wii has component  cables, try using that. As for cable, you might get a better signal with Digital Cable.
Apr 23, 2008 | Hitachi 46F510 46" Projection HDTV
Snowy Screen
sounds to me like you using coax wire from your dtv. how about trying s-video and audio cables. if using coax, then your prob using the push on wire that came with the sat. these go bad all the time.
Mar 24, 2008 | Akai PT5598HD 55" Rear Projection...
Fuzzy picture
does it look like this set?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba 42 inch rear projection TV
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Oct 23, 2007 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
