Question about Ruud UBHC Air Conditioner
Janitrol inside unit
It came on, in about 2 seconds it went off. Now it will not come on at all. Any ideas?
    Scholar:
  • 57 Answers
Do you have a digital t-stat?
If so does t-stat have batteries? bad batteries will give you problems.
Check you electrical breakers. Turn them off then back on to reset.
Does the fan come on if you set the t-stat to fan on?
Posted on May 20, 2008
What's wrong with my furnace?
The relay for the motor is stuck or the points inside the relay are arced closed. Replace the relay.
Apr 26, 2016 | Goodman Janitrol Amana Goodman Janitrol...
Replacing a janitrol hpt 18-60 with a Filtrete 3m-22
What is the question that you have about this? What is the make and model of the hvac unit that it is running?
Apr 21, 2013 | Filtrete Thermostat. 7-Day Digital...
I hooked up a coleman electric furnace to a janitrol condenser heat pump . The t-stat wires on electric furnace are red white green and yellow. I added a blue for common off of transformer for digital...
Hi, first of all you need to get a hand full of 5 amp auto type fuses and install one on the hot leg of the 24 volt secondary side of the transformer. Just use 2 female crimp on connectors and put the fuse in the middle of the hot wire. Saves $$$$ on replacing transformers when you have a dead short on the low or high voltage side of any transformer, just a trick of the trade, food for thought. Fuses are much cheaper. On your electric unit, you may not need the common on this to operate the digital stat if it has batteries. This may be your dead short. On the Janitrol condenser, the red is your 24v as you no. They are using blue in place of yellow for cooling. Red is hot, W is heat, G for fan, and blue is cooling on this Janitrol. Keep in mind you are connecting to a heat-pump also, so make sure the wiring is correct. Are you installing this for secondary Heat?? More then likely, the blue common you have added is the dead short as the janitrol uses the blue for a cooling relay in place of yellow. Anyway, use the 5 amp fuse, trick of the trade to save on the transformers. Please keep me posted, as I know know you have this under control.
Shastalaker7
A/C, Heating, & Refrigeration Contractor. Good Luck!
Feb 09, 2011 | Coleman Heating & Cooling
I have a Janitrol outside Package unit, Not sure of the year, the trailer is a 97 or 98, not sure and the problem is that when it gets colder outside, the unit does not blow hot air, it gets colder inside...
Sounds like uninsulated exposed duct work. You can insulate the duct work and check to see that your cold air return is pulling air from inside the trailer not from an outside source. If the problem is not with the duct work try setting the high and low limits for the fan up slightly. Normal settings are roughly around 150 on the high and 125 on the low.
Dec 13, 2010 | Goodman GMS90703BXA Heater
Have a Janitrol central air system and the unit outside comes on but the fan in attic does not always come on. If I go to the thermostat and manually turn it from auto to on it comes on. Any ideas about...
If the blower is working with the thermostat in the ON position that tells you that the fan motor works. In the AUTO setting... the system in controlled by the contacts in the thermostat. 1. The thermostat contacts might not be closing. 2. A contactor( or relay ) in the air handler unit(inside unit) might not be closing to send the signal to the fan motor. It sounds like a thermostat or relay problem to me. You can email me at Starztruck4u@aol.com if you have more questions.
Aug 05, 2010 | Heating & Cooling
My outside a/c condensing unit's fan runs, but inside vent air is not cold. compresser may not be running. inside vent air was cold last week. Janitrol ckj361ab is model # of outside unit.
Start the unit and go outside to see if the insulated pipe is sweating or cold, hot air should be discharging from top of outside unit. Since the breaker is not tripping, my best guess is the compressor is not operating. You might have to replace the capacitor.
If you can hear the compressor operating, then most
likely needs refrigerant
Jun 17, 2010 | Heating & Cooling
Our janitrol heat pump is freezing. there is considerable buildup of ice inside the pump itself on the coil. the fan still spins and still heats the interior of the home
Switch the thermostat from heat to Aux. or emergency heat till the outside unit thaws out. This will shorten the life of the outside unit considerable running it all iced up.
Jan 10, 2010 | Heating & Cooling
Janitrol gup power vent ignition sequence
inducer motor should run for several seconds before furnace lights, this proves the pressure switch and ensures proper ventilation
Sep 30, 2009 | Goodman Heating & Cooling
Cost to replace carrier 38ckc060
Did your unit work last summer? 10 Years old is very soon unless it is a cheap unit like janitrol or goodman. Most units last min. 15 years and 20 most of the time. Generally speaking any ways. To replace compressor cost maybe 750.00 to 1,000.00 you have a big house looks like. 5 Ton unit. The whole system could be 6000.00 to 8000.00 depending on grade of unit. I would get a second opinion though cause I am wondering if they are just padding their pocket.
Apr 16, 2009 | Carrier 38CKC060 Air Conditioner
Ruud UBHC Air Conditioner Logo
50 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
