Question about Belkin (F6C800-UNV-PL) UPS System
Need replacement battery for F6C800 Belkin UPS
All the battery websites I go to show a top terminal one battery replacement for this unit and they say thats correct. The case will NOT ALLOW a top terminal setup and needs two batteries side by side with SIDE terminals.
WHO SELLS THE CORRECT BATTERY ?? I can't even get a response from BELKIN..
Thanks, Bob Engelman, Mt Vernon, NY
Not working
Here is a link for the batteries . And look in the yellow pages any computer repair shop should do fine.
http://www.batterysharks.com/Belkin-F6C800-UNV-p/F6C800-UNV_UPS12-7_x2.htm?gclid=CLWpnJeZrbwCFelxOgodOjMA4A
Feb 02, 2014 | Belkin (F6C800-UNV-PL) UPS System
BELKIN UPS FAULT
Need good batteries. Then press and hold the power-on button until the magnetic relay is on.
Nov 26, 2013 | Belkin (F6C800-UNV-PL) UPS System
BELKIN UPS DOES NOT WORK
If the device is over a few years old, then the batteries are probably dead. If so, they can be replaced. Below link shows some photos of the device once opened.
http://www.pcstats.com/articleview.cfm?articleid=1092&page=2
I have a F6C800 and replaced the bateries. It seems to provide surge protection power through the 2 outlets but does not provide power through the Backup outlets. The monitoring software also does not...
OK - I'll ask the simple question first, so don't think I'm being crappy...
When you hooked the wires back up to the batteries that were replaced, did you hook them back up as they originally were? (I ran into this problem myself earlier today. I put one of the batteries in upside down and didn't have them hooked up correctly.)
Red terminal on the front battery goes to the black terminal on the back battery, then the black terminal on the first battery goes to the circuit board. Red terminal on the back battery goes to the power supply.
Hope that helps. It sure is a pain the change these batteries out.
Nov 29, 2010 | Belkin (F6C800-UNV-PL) UPS System
I want to connect a UPs to my computer and I don't which cable goes to a system unit or the monitor.Please show me the clip
shut down the comp and the ups
unplug the cable from the comp and plug it in to the ups i/p
take the iec male to female cable that came with the ups and plug male into ups o/p and then female into your comp
turn on ups then turn on comp
thats it
hope this helps
thanks for using FixYa
Sep 19, 2010 | Belkin (F6C800-UNV-PL) UPS System
Belkin 1500va (uses 2 - 12v 7ah batteries)
check out this picture, it shows the 2 batteries wired up.
Notice that the batteries are flipped opposite of each other.
So from left to right its: bottom red, bottom black, top black, top red
Between the 2 batteries there is 1 red to black connection.
Then black to black-wire to circuit board
and red to red-wire to circuit board.
Aug 22, 2009 | Belkin (F6C800-UNV-PL) UPS System
Belkin F6C120 UPS problem, won't test
Check the manufacturer's web site for upgraded software on your UPS. This sounds more like a software problem.
May 28, 2008 | Belkin (F6C800-UNV-PL) UPS System
Belkin ups not working properly.... green and RED light on ...indicates bad battery. But unit not more than 1 yr old, no battery time at all when plug pulled...not enen i min on (desk to an d monitor
Your batteries are weak...(causes
1:-not powering the UPS for a longtime
2:- long use(3 to 4 years) )...you will have to replace them
PLEASE RATE ME.................
May 25, 2008 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
Replacing the batteries in the belkin ups f6c800
look around the box and nottify the screw point open these screw and look for red and black cables that indicate the polarity of positive and negative, make sure the positive goes to it position as well as the negative on the new batteries.
Jan 22, 2008 | Belkin (F6C800-UNV-PL) UPS System
F6C800 no pwer to backup receptacles
that´s pretty strange and i would say that the batteries aren´t properly charged, try to let them charging over night without any load. good luck
Feb 18, 2007 | Belkin (F6C800-UNV-PL) UPS System
Belkin (F6C800-UNV-PL) UPS System Logo
264 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
