Blown speaker 3.5" speaker blown, any place other than BA to order a replacement?
  • 3 Answers
You can go to Parts Express and get most any speaker replacement you might need.Hope this helps.
www.parts-express.com
Posted on Nov 28, 2010
Need driver for Logitech Z-340 speaker system.
Sounds like the Subwoofer is blown. Unless you are handy with this stuff, you're outta luck unless you can find someone with the expertise to replace the blown speaker inside. This is not an easy job. If you are up for it you can follow the previously described method for opening it & removing the blown speaker. A suitable replacement can be found at http://www.rpelectronics.com/d03-0004-4-speaker-paper-cone-4-ohm.html Note that it will need to be mounted differently than the original which is mounted on the rear of the panel.
The replacement must be mounted on the front. It will need some sort of gasket (foam tape or something) between it & the panel. No soldering is required as push on connectors are used. Connect it up after installation and reassemble the unit.
Be aware that there is a possibility that the sub's amp is blown, in which case replacing the speaker is of no use. It would be good if you had some sort of speaker to connect to the terminals once you get the unit open and check that the amp is putting out before ordering a replacement speaker. Good luck!
Nov 17, 2012 | Logitech Z-340 Computer Speakers
Blown speaker
I do not know the manufacture but there are a lot of replacement speakers. If I was able to see the speaker i could order a reasonable replacement. You may contact Pro Line Music 215-736-8055 or servicedepartmentprolinemusic@comcast.net
Jun 10, 2011 | Velodyne HGS-10 Subwoofer
Brand New Ampeg Ba 600 210. Only Used durin 2 shows. Sound is awesome. Go to use it this weekend and absolutely no sound at all coming through the speakers. Compression, eq and Everything else working when...
Another person posting on here I suggested opening his unit and he had blown speakers. I think these that are DOA after previous use may be blown during the previous shutdown of the amp driving them and those with built in amps are blown when mixer is powered down putting out a large pulse. Hopefull the amp is blown rather than the speakers... cheaper to repair. Open and check for a fuse, but dont' replace it until you find out the cause of it blowing as additional damage can occur.
May 15, 2011 | Ampeg BA600-210 Bass Combo (with )
Boston BA7500G Speakers with no sound.
Well we have eliminated the laptop as a problem,.. that is very good. As far as what the problem with your BA unit is,.. we only know that it does not function with an external device (laptop and mp3 player). you already mentioned that a sound test from the unit plays through all the speakers,. right? With that lets start with the most basic item that will cause this problem,.. the cable that comes from the BA unit and plugs into the laptop or mp3 player. Is the cable plugged into the right place on the BA unit? Does the cable disconnect from the the BA unit? if so, do both ends of the cable look the same or is there 2 ends (maybe red and white) that plug into the BA unit? Please let me know when you can and we can continue troubleshooting this.
Feb 08, 2010 | Boston Acoustics BA7500 Computer Speakers
Aux cord is broken making the left speaker drop in and out unexpectedly. Is there an easy way to fix this, or a place to get a new aux cord? (This is the cord that connects to my computer with the green...
Do you have soldering tools? If so cut strip solder LIGHTLY tape it up and see if that does it.
New or replacement radio shack maybe
BA wep site and the usual e bay craigslist
b
Aug 04, 2009 | Boston Acoustics MicroMedia Computer...
No decimal display on TI BA-II calculator
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Jun 03, 2009 | Texas Instruments BA-II Plus Calculator
Default decimal settings
Jun 01, 2009 | Texas Instruments BA-II Plus Calculator
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
Speaker blown
check samsung parts had the same problem with speaker ordered replacement from samsung parts store works perfecct
Nov 06, 2007 | Samsung HLR5667W 56" Rear Projection HDTV
Speaker replacement
Try to find replacement speaker on amazon, here:
Amazon com cobra xrs 9500, I hope this was helpful.
Cheers
John
Oct 11, 2007 | XRS-9500 Radar Detector
771 people viewed this question
 Grubhead
Grubhead
