Memory dump how do i replace a memory file dump .. i have found the filethat has been dumpt what program do i open this file to replaces it .....
    Champion:
  • 207 Answers
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
Menu keep on poping up when tried to exit it goes back on the screen over and over.
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
also you might download and use this registry cleaner it is totally free to use
another one of the possibile reaons is
a bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to finish its cycle and have an end so any faulty leads will end up with a computer error
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
Apr 04, 2011 | Computers & Internet
I have the Acer Aspire One. My sound works however, every time I try to use Skype a blue screen comes up and it restarts the computer. As well when I play music it always skips and there is a static noise...
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 03, 2011 | Acer (54.AA806.001) Sound Card
I have almost same problem. This problem start one time when I using my computer. Computer always stop after trying restart, sometimes start normally and stop after few second. And now when I start...
hope this helps
Feb 25, 2011 | Abit KV8 Pro Motherboard
Invalid parameter problem keeps rebooting my computer
hope this helps
Feb 24, 2011 | Computers & Internet
My touch pad constantly freezes and is inhibiting my work flow due to restarting the notebook all the time. please help
hope this helps
don
Feb 23, 2011 | Computers & Internet
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
Can not dump photos from syber shot camera to my PC
Hi, Welcome to FixYa.
If you are using a memory card, you have to remove it from camera and put it in adapter and connect to computer using a card reader..
If you are having hard disk, Then use USB cable to connect to computer. computer will detect it as normal drive.
Here is a link which discusses same problem
http://answers.yahoo.com/question/index?qid=20090211174705AAHTq6l
Also the link below will help you in transfering files
http://www.microsoft.com/windowsxp/using/digitalphotography/takeit/transfer.mspxcorder-Review.htm
Jul 16, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
IBM R51 - "Registry Cannot Load"
I had the exact same problem. I basically gave up and decided to reinstall the O.S. But when I did it gave me an option to upgrade rather than install, and I found that all my programs and files were still there after. So you coulkd do that. I found out that some of the O.S. was corrupt via a virus so this was solved also.
Jun 05, 2009 | IBM ThinkPad R51 Notebook
Memory dump
Make sure your computer meets the minimum system requirements for running Windows XP if this is an upgrade - I had a computer that technically met the requirements, but boy did it run slow after I upgraded from Windows ME to Windows XP. If your hard drive contains no programs, information that you can live without, then you can completely reformat the hard drive and start over from scratch. If it does contain important programs, burn them to CD or DVD - and make sure that your computer can read the files after you are done burning - and then reformat your hard drive.
Mar 07, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
