Question about Samsung UpStage SPH-m620 Cellular Phone
Drop Samsung Upstage in water
I drop my phone in a cup of juice. WIll it work after the phone dries in the inside, or I might have to get a new phone?
  • d_wuensche27 Sep 03, 2008
    the same thing happened to me and im wondering if there was a way i could remove the cover so i can let the inside dry. thanks
  • mochospicet Nov 01, 2008
    I dropped my upstage in a cup of water. When i turn it on buttons dont work and it acts crazy. Im trying to take it apart but I really dont know how.
Wow, himan and masir really have no idea what they are talking about. clean it properly before inserting the battery? remove the battery and get it serviced? you 2 are idiots. the upstage battery can't be removed without disasembling the entire case and then desoldering the battery from the board. i bet you 2 are probably the same people that get complaints left and right when people call dell and get an outsourced call center...
Posted on Nov 28, 2008
    Sergeant:
  • 282 Answers
Yes, it may work but you need to clean it properly before inserting battery. Disassemble the phone. Clean the whole inner side board
Posted on May 19, 2008
    Sergeant:
  • 218 Answers
U must quickly remove its battery and get it serviced at samsung service center
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
I dropped my phone in a cup of coffee. I quickly retrieved it and dried it off, and almost everthing works. But one thing that doesn't work is the microphone on outbound calls. I dial the number, the...
Take your battery out and place your phone and battery into a bowl of dry rice it should dry out any water thats still inside. Hope it helps!
Mar 10, 2010 | Samsung Cell Phones
Drop my samsung g600 in cup tea last nite not working
1st thing to do take battery out to stop power do you no how to take phone apart? if no there is a website that shows you cause dry it with a cloth then go over it with a toothbrush and leave for 12hours and see what happens then
Jan 20, 2010 | Samsung SGH-G600 Cellular Phone
SonyEricsson T707 was dropped into water. On recovery (2mins ) later stripped outer covers off and removed battery and sim card. Used hairdryer on unit for about 20mins. Can you suggest anything else I can...
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, but fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one so as not to risk it leaking battery acid in the future.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in water that isn’t pure such as a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours. Unless you have insurance for your cell phone which covers water damage, there is no point in sending it to the manufacture with the hope that they will replace it under warranty. If you drop your cell phone in water, the technicians will be able to tell immediately due to moisture sensitive stickers that are contained inside almost all cell phones. The best thing to do is to try the tips mentioned above and repair it yourself.
Jan 03, 2010 | Sony Ericsson T707 Cell Phone
Not charging
your battery is gone mostly. Try with the new battery it should work. When you drop battery in liquid, it shorts and doesnt work. If in warranty call samsumg customer support. Do not continue to use as it may cause more problems with your phone.
Apr 14, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Went into washing machine
The battery can not be taken out. It can on't by replaced by a specialist. Im sure the phone will not work now. You may have no choice but to get a new phone. Im sorry
Jul 29, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Take apart cell phone case
you can try to make your phone dry, and is possible that your phone will work. but eventually it will stop working
Feb 29, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Samsung UpStage SPH-m620 Cellular Phone Logo
404 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
