Keil compiler what is keil used in embedded systems,.. can u give a describe explaination
    New Friend:
Keil is a IDE software which means it is an integrated software, having different tools(assembler, compiler, linker, code editor, debugger ...) integrated into one single software-Keil.
The compiler used by Keil is called C51. Keil software is produced currently ARM LTD and ARM Germany GmbH but intially by the software inverter whose surname is Keil.
Keil is used for writing assembly or C or mixed programs for microcontrollers such as 8051, debugging code, linking the obj files and generating hex files.
http://appliedelectronicsengineering.blogspot.com/2015/05/how-to-program-microcontroller-using-Keil-IDE.html
Posted on Oct 24, 2015
In keil compiler ,we can mix assembly and c . But if i want to access particular ram location from c routine which is continously changed by my assembly code running in interrupt.
Posted on Aug 13, 2008
  • 54 Answers
Ya keil is a software which used for making hex file for microcontrollers and after that we insert this file to microcontroller by assembler .in keil you hv to use a c similar language.i am expert of embeeded system if u hv any further quiery then u can call me also at 9811613568
Posted on Jun 11, 2008
Cant install #.jad file even after formatting my nokia n73
About this result
JAD (file format) - Wikipedia
https://en.wikipedia.org/wiki/JAD_(file_format)
  1. Cached
  2. Similar
Java Application Descriptor (JAD) files describe the MIDlets (Java ME applications) that are distributed as JAR files. JAD files are commonly used to package Java applications or games that can be downloaded to mobile phones.
JAD File - What is it and how do I open it? - File.org
file.org > File Help Guides
  1. Cached
  2. Similar
Did your computer fail to open a JAD file? We explain what JAD files are and recommend software that we know can open or convert your JAD files.
What is JAD? What Opens a JAD? File Format List from WhatIs.com
whatis.techtarget.com/fileformat/JAD-Java-Application-Descriptor-file
  1. Cached
  2. Similar
JAD files describe the contents of a MIDlet, a type of Java application commonly used for games and applications for Java ME (Java Micro Edition formerly known as J2ME) for mobile platforms and embedded systems. JAD files are used to identify retrieve and install MIDlets.
and finally, how to fix
Cant install jad file even after formatting my nokia n73 Google Search
Dec 01, 2016 | Nokia Cell Phones
Can you give an example of compiler using vb?
Dim parameters As New CompilerParameters() Dim results As CompilerResults parameters.GenerateExecutable = True parameters.OutputAssembly = Output results = icc.CompileAssemblyFromSource(parameters, SourceText)
The code above uses the CompilerParameters object to tell the compiler that you want to generate an executable file (as opposed to a DLL) and that you want to output the resulting assembly to disk. The call to CompileAssemblyFromSource is where your assembly gets compiled. This method takes your parameters object and the source code, which is a string. Once you compile your code you can check to see if there were any compilation errors. We use the return value from CompileAssemblyFromSource, which is a CompilerResults object. This object contains an errors collection, which contains any errors that occurred during the compile.
There are other options for compiling, such as compiling from a file. You can also batch compile, which means you can compile multiple files or sources at the same time. Additional information on these classes is available on MSDN Online:
Feb 17, 2011 | Microsoft Visual Basic 6.0 for PC
How do I get a setup.exe to run from an external drive?
You cannot run a Set up file in the SYNET07526. It is an "Embedded" system and everything used must have the DDL files already written into the registry upon compilation. Those setup files are for a WinXP or Win7 system that allows direct writing to the registry.
Feb 07, 2011 | Sylvania G-Netbook
I cannot hear any sound on my audio speaker and i dont know what software should be installed. :(
Hi Keil,
Its not clear what is your computer make / Operating system that you are using on your computer. Would suggest you to visit your computer manufacturers website and enter your computer model and operating system and you will be allowed to download the audio drivers once when they are installed you will be able to hear sound on your computer
Jan 02, 2011 | Computers & Internet
Plss!! give me the few steps to run c program in command prompt
Light-Weight C Compiler for windows: Tiny C Compiler. http://www.tinycc.org/
Last version download: http://download.savannah.nongnu.org/releases/tinycc/tcc-0.9.25-win32-bin.zip
To compile: tcc.exe source_file.c -o compiled_file.exe
May 24, 2009 | Dell Computers & Internet
I have vista 64 bit osis there any tc/c++ compiler that can run
You may try donloading Dosbox which is an Excellent program for running all 16bit and 32bit Programs
OR
you can checkout Dev++ which is a C++ compiler for all 64bit and 32bit Operating Systems as an option. Search it on Google and Download it may be better compiler for Vista than the traditional C++!! Rate if the answer helped!!
Feb 02, 2009 | Microsoft Windows Vista Ultimate Edition
When i write the program exception handling in c++. it give the error try and catch keyword. how to handle the Exception handling in c++
You might be using old compiler. Use a latest compiler such as Turbo C++ 4.5 or later. The older versions 2.0 and 3.0 does not support exceptions.
Jan 21, 2009 | Computers & Internet
Help embedding FLASH video on web page
Hi
You can use this for embedding it
http://www.videospark.com/index.php?ssp=24
or you can go through this nice tutorial for embedding flv in webpage... it clearly explains you the solution
http://www.boutell.com/newfaq/creating/video.html
Thanks
Mohan
Oct 07, 2008 | YouTube Videos
Compilation error in Turbo c++ 3.0
Can send your program to me i will try to clear it
Feb 22, 2008 | Borland Turbo C++ Suite 1.0...
What is ICC profile?
ICC profile can be used in any ICC aware application or platform, and describes usable information to convert into a color space which defined by ICC (International Color Consortium). DiMAGE A1 has a function to embed ICC file to the captured image. Please make use of the function "Embedded Adobe RGB" to use correct color information on application software which corresponds to color management system.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Computers & Internet Logo
531 people viewed this question
David Payne
David Payne
