Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Memory error wat is :instruction at 0x10012314 reference memory 0x000000 memory could not be read means and how do i solve this problem? thanks
Its an message of faulty memory, means some components of RAM is working well and some components are not, some instructions you can follow but its not possible to make the RAM work again.
Instructions
1) Clean the RAM and again put that .
2) Check the harddisk data & power cables are correctly inserted.
3) Or try to boot again
Posted on May 19, 2008
How to fix eror code 68.2
The error means the storage device that you are storing jobs is full or out of space. 68.2 may mean a DIMM slot? Are you using a memory DIMM in addition to was is standard with your CLJ3000? If so, it may be full or out of memory or possible incompatible. If you are using a external hard disk, you may be out of space and may require you delete some files.
And I share a link please visit and read instruction guide. I hope solved your issues.
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-bpl12422-6%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N10D64
Thanks,
HP Printer Support
May 29, 2014 | HP LaserJet P2015dn Printer
Engine is turning over but will not start odometer reads error 1 and is flashing" hi". How do I solve the problem
hi i cant really answer this as u didnt state what type of bike it is. if you refer to your owners manual it should tell you what error 1 means. as every error number is a different problem it could be something simple just wont fire due to safety features i hope this helps you. thanks ladjr2
Jul 30, 2011 | Yamaha YZF-R6 Motorcycles
Wat does 5200 error code mean? wat is an IP address?
HI there.
Our experience has shown that this error message is solved by performing a manual setup on the Nintendo DS. Please follow these steps: The first thing you'll need to do is find out what IP address range you should be using. To do this: Click the "Start" button in the lower left-hand corner of your computer. Next, you will need to access the command prompt. To do this: Windows XP users click "Run." Windows Vista users click inside the search bar. Type "cmd" into the box and press Enter. Type "IPCONFIG/ALL" and press Enter. The IP address, Subnet Mask, Default Gateway, and DNS servers of the PC will be displayed. The IP address you are going to assign to the Nintendo DS must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110). The DS and PC must have different IP addresses. Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS. They must be the same for your Nintendo DS and for your PC. Click here to go to our Wireless Router Configuration page. Use the drop-down box on the left to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing the settings found in the Special Notes. Follow the instructions and test the connection. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this on your Nintendo DS or Nintendo DS Lite, please click here. Check Nintendo's router info for special notes, if available, for your router. If you try these steps and you get a different Error Code, please review the values that you entered carefully, since an incorrect manual setup will cause another Error Code to appear. If the 52000 Error Code persists, than the problem may be caused by a basic setting in your router such as transmission rate. Please carefully read the instructions below: If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Thank yo for using Fixya!
Jul 07, 2011 | Nintendo DS Console
Laptop start up error
This error comes when there is memory issue .
Harddisk issue or RAM issue.
For that if you have windows recovery disk you need to run disk checking program
Most of this error comes becuase of hardddisk error.
Boot your computer with windows xp disk then enter in recovery console mode then type in prompt "chkdsk /r"
then press "y"
then it checks disk andf fix error if found any error on harddisk.
then you can boot your windows.
Thanks for using fixya.
Please rate my solution if it hleps.
Pls let me know if you need more assistanse.
Many Thanks .
Jul 24, 2009 | Acer Aspire 4315-2963 Notebook
A problem has been detcted and windows had been shut down to prevent damage to your compuetr
This is a windows stop error. Are you running windows XP?
If it is the first time you have seen it you can try restarting and it may never appear again. If it does:
At the bottom of the screen you will see some text saying STOP ERROR: 0x000000?? (0x???????? 0x???????? 0x???????? 0x????????)
Look at the code prior to the brackets 0x000000?? - write it down and google "STOP ERROR 0x000000??".
This will let you know what is causing the STOP error. Very common reasons for this are component reseating required and disk-checking. You can run a diskcheck through the Windows Recovery Console (can be installed to hard-disk - simplest way is to install combofix and follow the onscreen instructions - or run from your windows installation disc).
Jul 23, 2009 | Dell Dimension 9200 PC Desktop
What do you mean by this error? "The instruction at 0x003bfc61 refferd memory at 0x305eff8 the memory could not be written".
most likely it is a software error, as the pc is shutting all of the running programs down to turn off the PC, that is where the error comes in, you could try to stop some of the background programs to try to figure out exactly what app it is refering to. It will probably not harm anything unless it is a program like word or something and you haven't saved the document, if that can't be written before the PC shuts down, you would lose your work. If it is a memory issue with the actual RAM, you can run a memory test in windows under all programs Administrative Tools, or in the control panel under Administative Tools, and then Memory Diagnostics, to check the hardware,
Please give a fixya if this helps or solves your problem
May 15, 2009 | Computers & Internet
Window startup error
Looks like a spyware or an invalid application running with errors in the back ground.
You can access Event Viewer by selecting Start, Control Panel,
Administrative Tools, and Event Viewer. When researching the meaning
of the error, information regarding Event ID, Source and Description
are important.
or try running a spyware scan to get that out of the machine.
Thanks
Fame !
May 05, 2009 | Ahead Software Nero 6.0 (60045) for PC
Error message: The instruction @ 0x1004628 reference memory
Hi there go to microsoft.com and search error codes and it will give you all of the information about the error and it's meaning
Mar 17, 2009 | E-Machines eMachines Desktop PC
Wont boot just has series of beeps
Table 2. System Beep Codes
Beep Code Possible Cause Corrective Action
1 Memory refresh failure Reseat the DIMMs.
2 Parity cannot be reset Reseat the DIMMs.
3 Memory failure within the first 64 KB of memory Reseat the DIMMs.
4 Timer not operational See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
5 Processor failure See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
6 8442 keyboard controller error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
7 Processor exception error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
8 Video display memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
9 Optional ROM checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
10 CMOS memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
11 BIOS checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
Jan 11, 2008 | ASUS K8V-MX Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
88 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
