Question about Nokia 6300 Cellular Phone
Re bluetooth thks for the response but how do i reformat..the phone doesn't stay on..and i've tried connecting it the the computer as well it doesn't stay on..
    President:
  • 1,017 Answers
How to reformat your phone,
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Posted on May 22, 2008
How to connect to internet in laptop using nokia phone
I have got internet connection from my slide (EDGE). Nokia PC suite seems to offer such a connection via Bluetooth through my phone by calling it One Touch Access. Bluetooth connection is perfect, my phone alone connects to the internet but not my laptop through my phone. What needs to be done?
Oct 06, 2012 | Computers & Internet
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
Transfer of photo's from phone to computer
Hi
Did you have any luck connecting to the PC?
Tried mine but couldn't connect through the USB [no phone found!]
Could've tried bluetooth but then again,it doesn't apply here.
Thought this device could never connect to a PC!
If you can connect,just open the folder with the pictures and drag them onto the desktop.
Mar 03, 2012 | Sony Ericsson Cell Phones
My bluetooth doesn't switch on
nokia 3310 does not provide bluetooth
Mar 01, 2012 | Nokia 3310 Cellular Phone
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
My nokia 5800 can't find the bluedio AV890!!!!
may be due to the difference in blue tooth standards. if this then not any chance of connectivity.
Jun 29, 2011 | Nokia Lands Phones
I'm trying to connect my phone to my laptop
Via Bluetooth or Manual Connection? I'll tell you how to do both.
Bluetooth
To check if your computer has bluetooth, Click the windows logo at the bottom left. Type "bluetooth"
and it should come up. If it doesn't, then you need to buy an adapter. Then click bluetooth, search for your phone (make sure bluetooth is enabled) and it should appear. Then your phone will act as if it is connecting to another phone.
Manual
If your phone didn't come with a cable to connect it to your computer, then you will need to go out and buy one. When you plug in your phone, it will be automatically scanned and added to your computer as a compatible device. From there, it will appear as a new drive under Start > Computer > and it will probably be called Removable Disk.
Jun 02, 2011 | Computers & Internet
I've tried already all the solution that you have posted on your fixya wall but sad to say it doesn't work. please help me on hoe to reformat my nokia 6300 china made in.
format operation
you have to download nemesis service tool program from internet to your PC
and read the instructions
then connect your mobile phone with the PC via usb cable or box cable and continue
May 09, 2011 | Nokia 6300 Cellular Phone
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Problems pairing with PC via Bluetooth
Guest - let's remember that wireless is not bluetooth on a computer if your computer does not have bluetooth then you need to buy a bluetooth adapter.
batin73 - I really can not say why that is happening with you pairing the system to the phone.....i will check on that and get back to you.
Feb 02, 2008 | Nokia 6126 Cellular Phone
Nokia 6300 Cellular Phone Logo
42 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
