Question about Microwave Ovens
Microwave runs just will not heat. Changed power level still will not heat! Bought in April 2008. Have not used that much.
  • Anonymous May 19, 2008
    sylvani microwave run but stop cooking
  • Anonymous May 22, 2008
    Same problem as tootsiepop5's, my microwave is panasonic dimension4-model NN-B706/B756, Before , I don't have problem with my microwave until recently I used the convection , now I cannot use the microwave function anymore.The microwave function works well but no heat, however the convection seems to be working well.
  • Microwave Ovens Master
  • 9,098 Answers
Tootsiepop5 - Your unit is less than a year old, so it should be under warranty. I would contact the manufacturer for warranty service.
Guests - Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2008
How do i adjust power level
There are no heat levels on a microwave oven, only power levels. I am not aware of any method of checking the power level except to boil water. Boil water at each level and time how long it takes to boil. The lower the power, the longer it should take. If there are no differences in the time, the oven is not functioning as expexted.
Sep 13, 2014 | Haier Microwave Ovens
Emerson Microwave MW9325SL
Failed magnetron or power supply.
Aug 12, 2017 | Microwave Ovens
I have a GE microwave, sensor type...it runs but does not heat and does not allow us to change the power level. Any ideas? It is barely over a year old. Bought at LOWES.
This sounds like the magnetron has gone, also there is a solid state device called the triac which controls the power level settings. The other two parts that can be a factor is the high voltage capacitor and diode. The repairs with parts and labor can amount to the price of a new microwave oven.
Feb 28, 2011 | GE JVM1850 1000 Watts Microwave Oven
Microwave does not heat if time is less than 1 min 30 seconds
Generally speaking, charcoal filters should be changed and grease filters should be cleaned about every six months, or whenever you notice they are getting dirty & clogged. Yours will likely have one or the other - probably not both - depending on whether it's vented or it recirculates.
A clogged filter will cause the supply of cooling air flow to be lessened, allowing the magnetron to overheat. It only takes one severe overheating to damage or destroy a magnetron.
One common way for a magnetron to fail is that its heating power is less and less, then it just stops heating.
Magnetron's will usually have a warranty of 5-9 years, but you'd still have to pay the installation labor.
You can save a $75-90 home visit by removing the oven form the wall and taking it to a local Whirlpool-authorized warranty servicer.
The date of manufacture will be on the model tag in the unit, and the warranty terms will be in the owner's manual. Many manufacturers will use the serial number and date of manufacture to validate the warranty in lieu of a sales receipt.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Jun 26, 2010 | Whirlpool WMH1162XV Microwave Oven
The paint (or whatever it is covering the bottom)
Check the 3 wheels on the circular plastic part that's fitted below the turntable.
It sounds like they may need some filing down. Run your fingers around the wheels to see if there are any sharp bits of plastic that could be cutting into the paintwork on the base.
Clean out the base of your oven and apply a thin film of vaseline to each of the 3 wheels. This will help rotation in future.
Remember to keep cleaning out any excess food particles that may lodge below the turntable, as these will eventually slow down or stop the rotation, which in turn means that your food is not heated evenly throughout!!!
Nov 18, 2009 | GE JE2160 Microwave Oven
Microwave exploded.
Did it make a popping noise, like a .22 cal pistol? Probably one of the larger capacitors on the power supply blew up.
Mar 06, 2009 | Emerson MW8168B Microwave Oven
...have Danby 1.0 cu. ft.
When talking about "Power Level", there is a misconception that the cooking power is being adjusted. This is not the case. The user is actually adjusting the duty cycle of the Magnetron. For instance at 30%, the Magnetron will be turned on for 20 sec. and off for 40 sec. A loud 60 cycle hum is usually caused by a shorted Magnetron. Thus the unit is not economically repairable.
Sep 30, 2017 | Danby Microwave Ovens
Microwave oven
maybe it is running. you can not change power while the unit is running. you can only set the power level while programming the heating schedule.
Feb 18, 2008 | Microwave Ovens
Hotpoint RVM1425
The first thing I would suggest is to turn off the breaker or unplug it from the wall for a few minutes to "reset" it, then try again. If a reset doesn't fix it, I would think you may have a defective magnetron. When you heat something of very low moisture content, it can lead to microwave energy not being fully absorbed, but instead being reflected back to the magnetron. This can damage it. This is usually best left to a pro to repair. In case it might help, your owner's manual can be found online at: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=RVM1425BA
Nov 21, 2006 | Hotpoint RVM1425 Microwave Oven
Microwave Ovens Logo
125 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
