Question about Radio Communications
Jvc KD-LH3101 cable connections
Hi do you know how to connect cables from that radio
SOURCE: Unable to connect USB hard drive to KD-AVX33
I have a Lacy 160G laptop external HDD attached to it..It works fine... The format of the HDD should also be FAT32. The structure of the files should be Album/MP3
For a HDD that big look for software on the internet which can convert it from NTSF to FAT32 it should work perfectly.
The only thing I haven't been able to get working is videofiles...on the same HDD. Anyone got an idea?
Posted on Feb 26, 2008
  • 298 Answers
SOURCE: I just bought a JVC
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Posted on Apr 03, 2008
soundinstall
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Posted on Mar 02, 2009
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Posted on Jun 10, 2009
dj_relly999
  • 4070 Answers
SOURCE: Ipod Connection on JVC KD-S550 CD Player
hi, most of the slots that plays the ipod is in front of the head unit panel, if you dont find any slots in front then it will be nowhere at the back for it will be hard to access. hope this helps, have a nice day
Posted on Feb 12, 2010
I had a 98 toyota tacoma with a completely different radio system and where i used to have perfect service connection to a radio station and now with my 2001 ford focus and the jvc kd-g140 radio i barely...
Hi Sarah,
The problem will lie with one or combination of the radio, the antenna or antenna cable. Check the antenna. If it is the type that can be unscrewed from the body of the car, do so. Check and clean any mating surfaces. Dirt & oxidation are enemies of electrical connections. Check the antenna cable everywhere it is exposed. Look for cuts in the jacket which can allow water in and causes oxidation. Check the connection at the radio, too. Make sure it is free of dirt and oxidation too. Clean the connectors and reconnect. Be sure that the plug connections are fully seated in the jacks. If you find a damaged cable or connector, it should be replaced. many times, replacing the cable will be very difficult - you might want to try installing a new antenna and cable instead of trying to reuse the old antenna. These are often available for sale in the automotive sections of department stores, and in automobile specialty stores. Try connecting everything together to make sure it works before punching holes in the body of the car.
The issue may be the radio itself. Try connecting a different radio - either an identical factory radio that is known to be good - or an aftermarket radio to is also known to be good. All of these issues can be a logical point of failure - especially if you purchased the car used. There's no telling how the car's radio and antenna might have been used or abused before you took ownership of the car.
Nov 22, 2010 | JVC KD-G140 Car CD Player
Can I use a Chrysler/Infinity amp with aftermarker JVC radio?
it wouldn't be advised unless there are rca connections into the amp. these are the same as the inputs in the back of the jvc. It is possible to connect into an amplifier using speaker cable but i wouldn;t advise doing this unless you know what your doing.
May 15, 2009 | Kenwood KDC-MP235 CD Player
CONNECTING AN AUX CABLE TO PLAYER
Unfortunately, you can't. I have the same deck, and it has no aux in capability. The S5050 is simply a CD player, not even an MP3 player.
Mar 25, 2009 | JVC KD-S5050 CD Player
Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Mar 16, 2009 | JVC KD-LH810 CD Player
Jvc kd-pdr31
I believe You have to have the right auxillary connection to plug it in -- looks like in the lower right hand corner if you are looking directly at the unit.
Apr 17, 2008 | JVC KD-PDR30 CD Player
How do i connect an HU JVC KD-AVX1 to a Clarion EQS746?
use the front pre out from yur radio. and fade on your radio all the way to just the front. as if you were trying to only hear music from your front speakers.
Feb 07, 2008 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Problem with jvc-avx1 car dvd player.
actually it works better if you just ground the hand brake wire. by securing a section of exposed wir with on of the main body screws.
Aug 23, 2007 | JVC KD-AVX1 Car DVD Player
Power comes on and off
hi maybe the cable from yor power cable is thin.you need to connect a cable directly from your battery and noy via your ignition
Feb 08, 2007 | JVC KD-S6060 CD Player
Radio Communications Logo
79 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
