Suggests a power failure. Check loose wiring at the junction box where power supply is connected. Check white and black wire connection to electronic control board. See if flipped switch in fuse box for line to dishwasher.
Just one possiblity. Others include burnt out heating element or bad pump. Time to check warranty for service call.
SOURCE: i have a frigidaire dishwasher and sometimes in
Hi it sounds like the main PCB module, are you getting any fault with the lights flashing???
SOURCE: fridgidaire diswasher brand new high temp wash and
Thermostat needs to be adjusted or replaced.
SOURCE: my frigidaire fdb1100rhm dishwasher detergent
Check for correct water pressure to the dishwasher. Could be a restriction in the 1/4" water supply line.
SOURCE: Frigidaire dishwasher won't dry dishes.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
