Question about Pitco Frialator SG14 Deep Fryer
No Pilot Light
The pilot will light but when you release the button it goes out, will not stay lit, I have replaced the pilot generator with same results..
  • burzerko
    burzerko May 11, 2010
    What do you mean by the generator is this a thermocouple or a thermopyle. Also does this use a conventional gas valve or a pilot safty valve.
  • Anonymous Mar 30, 2014
    Pilot lit but goes out when you release the button
    Champion:
  • 254 Answers
This device actually uses a thermopile it is part number P5047541. There are two things to check here ensure that you have had the right part installed be verifying the part number and also check that the sensing end of the thermopile is directly in the path of the flame.
Posted on Jun 04, 2008
Why won't the pilot light stay lit?
You have a "pilot generator" that sits in the flame of the pilot light. This generates a low voltage output from the flame of the pilot light. This voltage goes to the gas valve and tells the valve that the pilot is lit and to keep the pilot gas line open.
In almost all cases replacing the pilot generator will resolve the issue . They run about $60-$75.
Other causes may be the gas valve itself or a short in the safety loop, in either case should be looked at by a pool tech.
Jul 10, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Sep 10, 2009 | Coleman (5040B750) Patio Heater
Pilot light won't stay lit.
Ensure that gas is getting to the pilot , or you may have a devective pressure regulator.
If gas is getting to pilot and pilot is turning off, then you need to replace the thermocouple.
The thermocouple function is to turn off the gas if there is not enough temperature, so to prevent gas leaks if the pilot light goes off.
Near to the pilot light there should a part similar to a small metal tube directly in contact with the flame. Thermocouple is wired back to the gas valve.
When the pilot is on, and temperature is steady, the thermocouple will generate a small voltage that will keep the gas safety valve open. In case the pilot light goes off, the thermocouple will cause the valve to close. When you hold the pilot light button , the thermocouple will normally reach enough temp to keep valve open.
If the termocouple is faulty, it will turn off as soon as you release the igniter button.
Replacing thermocouple is an easy repair.
Call the number listed on the owners documentation to get the replacement part.
Sep 05, 2009 | Imperial IFS40 Deep Fryer
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Water heater will not stay lit even after replacing thermal coupl
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
Jul 16, 2009 | Kenmore Dryers
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
I need to know how to light the pilot on my somewhat old water heater. The model is called the challenger 5 the model number 153.331471
On these older gas water heaters there is a gas control with temperature selection and below that is a removable cover. Once you remove the cover you can gain access to the pilot. You must rotate the knob on the top of the control to the pilot position. When in the pilot position, hold the red button down and light the pilot. Continue to hold the button down after the pilot is lit for about one minute. If when you release the red button the pilot goes out, try one more time. If it goes out again after releasing the button your thermocouple is bad and must be replaced. The thermocouple generates a millivolt electrical current that hold the gas valve in the operating condition when the pilot is lit. When the pilot goes out there is no heat to generate this small electrical field.
Jun 08, 2008 | Kenmore Heating & Cooling
Pitco Frialator SG14 Deep Fryer Logo
171 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
