Question about Denon Audio Players & Recorders
You switch the amplifier on and then it switches itself off after 10 seconds
  • 1 more comment
  • sparkey714 Jun 13, 2008
    Denon avr-1508 goes into protect mode. Troubleshoot guide says it's a power source problem. I have tried multiple different outlets but no luck. supply Voltage/amperage are all good. Any suggestions ??
  • corey_hitman Oct 15, 2008
    hi there i have maybe used my denon avr-485 2 or 3 times and not even very loud and now when i goto use it it turns on as u say and the stand by kicks in after only 10 seconds WHAT DO I DO ?
  • elcaballo Feb 19, 2009
    AVR-2800 5.1, cuts off after short period of time playing.
  • 4,234 Answers
This unit is in protect mode that shuts down the amp section to prevent further damage. Please post the make and model so that I can provide details.
Thanks,
Dan
Posted on May 19, 2008
Some one broke off my power switch, I still have all the parts but the switch itself is missing the two plastic nipples on either side. Where/ how can I get a replacement/repair? -thanks
It is very hard to repair the internals of the switches and they are not too safe when you do so... best to replace the switch with a new one. Most of the switches are $10 or so max. Better hardware stores often have suitable ones or go to Digikey.com or Mouser.com and search for switch.
Jan 11, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Hi my amp when i switch it on within 3 seconds it automatically switches off?
HI...
That's the protect circuit kicking in.
The rec'r will require service. Either a couple of power supply capacitors have gone bad or one of the power amp modules has quit.
Nov 02, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
My 94 blues deluxe switches channels by itself .happens occasionally.it will switch to the overdrive channel, then a few seconds later switch back to the clean channel.
IF YOU ARE USING the footswitch, then likely problem is with cable and or the pug and jack.
IF YOU ARE NOT using the footswitch the contact switch on the jack for the footswitch is PROBABLY intermitent contact. These jacks are POOR quality in the music equipment. If this is the case in yours, open the unit and tighten the spring contact.
May 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Power fault
Maybe the audio amplifiers of your device are fried and need ton replace him
Mar 17, 2009 | Audio Players & Recorders
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Teac A-H300 Amplifier
I found the problem....one thread of one of my speaker cables was touching the backboard of the amp and shorting out - problem solved!
Mar 30, 2008 | Teac A-H300 Amplifier
Car audio
You need to use a multimeter to see if the remote turn-on voltage at the amplifier is dropping to near 0v as soon as you switch off the head unit. If it's not, you need to determine why it's not switching off quickly.
Dec 28, 2007 | Kenwood KAC-7202 Car Audio Amplifier
My amplifier
The "switched off by itself" is indicative that the auto-protect is acting. Auto protect senses that there is something wrong within the unit and rather than the damage extend to other areas, it simply switches the entire unit off. On some models, this also hold true if there are no or faulty speakers connected to the receiver. In others, this happens when there is no intelligent signal received such as in FM when an antenna would be required.
If you have verified that it is not poor signal, speaker problem, then perhaps your best bet would be to seek the services of a qualified audio technician since this would involve electronic circuitry/component diagnosis, soldering and the use of a DVM.
hope this be of some help/idea. Post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 03, 2007 | Audio Players & Recorders
Amp problems
From the above symptom, it show that the output stage of the amplifier have some problem.The protection cct come in to cut off the amp. when the output shorted or have Dc voltage.( this is to prevent further damage to the amp. & speaker ).If you know how to repair , just check on the pwr transistor (with heat sink )or else send it to the repair center.hope it help.
Aug 21, 2007 | Harman Kardon SIGNATURE 2.1 Amplifier
53 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
