Question about LG Studioworks 440SI 14" CRT Monitor
Monitor not working
Sir,
i have some knowledge of monitor repairing. sir i have a LG 14'' monitor but my monitor is offline . i see the monitor and deside a mosfet 7n60 is expair and idont collect this mosfet in my town. so, can i replace this mosfet to another.
Ya 6n60
Posted on Aug 16, 2008
Sir i had purchased 20 "led LG monitor B4 15 says.Now there is white , blue vertical lines in the led monitor. What is the problem
The monitor is defective and it needs to be repaired or replaced. Contact the place of purchase or the manufacture.
Feb 28, 2011 | LG L1915S 19" LCD Monitor
Hello sir, i hav LG CRT 15" monitor. After turning on, its LED continuous blinks and power button does not work and displays nothing. so plz suggest me what should be deffect?
Any 15-inch CRT-style monitor should be replaced by a 15-inch or 17-inch LCD-style monitor. You can find "previously-owned" monitors for $30 to $50, which is less than taking your CRT monitor to a TV/video repair-shop for an *attempt* to get it repaired.
Oct 04, 2010 | Computers & Internet
I have purchased lcd 14 inch monitor some 4 years back,due to handling the screen broke.now can i replace at your showroom or any other remedy is available.
Not practical to spend money on 14" LCD panel on 4 years old monitor, it will caost more than 19" monitor.
Put the money toward new monitor, I will not even repair it myself if it were my.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 24, 2010 | LG L1915S 19" LCD Monitor
SIR I have a lg 19 monitor having problem is
It sounds like the monitor is shutting down after you have it on for a 1/2 hour or hour, is that right? If so, and you can turn the monitor off and back on, and it's ok again, that means you probably have a temperature problem with some component in your monitor. It will have to be serviced and troubleshot to get it working again. You can use it the way you're doing now, and it will probably work like that until you can get it fixed. Make sure you get an estimate from a repair shop first, because often the cost of repair can be almost as much or more than a new monitor. Good luck, and hope this helps.
May 13, 2010 | LG Flatron L1919S LCD Monitor
Lg 500g monitor blinking in bi-color, no display when powered up
Sir,
there could be two possibilties for that
1 That your serial cable is not working or have broken pin .
2 Another is that you monitors picture tube has got damaged or burnt.
Usually it is second reason it can be repaired but is more expencive so i would prefer buying new one.
Nov 08, 2009 | LG Studioworks 563N 15" CRT Monitor
Not working 1024 by 768 pixels resolution
reduce the number of colors until you can get a resolution that works the monitor cant handle the number of colors and the number of lines of resolution this is a common problem with older monitors.
l8r
Nov 13, 2008 | LG Studioworks 440SI 14" CRT Monitor
Power supply get dropped
what power supply do you mean Sir/Ma'am.
is it the AVR (automatic voltar regulator)?
if its the AVR, just switch it on and check the output voltage with a multimeter (AC range 250)
you should see the voltage output nearly equal to your SERVICE AC voltage
Nov 06, 2008 | LG Studioworks 440SI 14" CRT Monitor
Whenever system restart , led blinking, no display
15" Monitor warranty period 1 year from mfd date.
17" Monitor warranty period 3years from mfd date.
Aug 22, 2008 | LG Studioworks 45 14" CRT Monitor
No video display
It is the problem of video amp. ic plz chage it.If only red colour is miss then check red driver transistor and cable
Jan 12, 2008 | LG Studioworks 45 14" CRT Monitor
Monitor problem
Your request for the exact problem will require a signal injector and use of an oscilloscope or even more test equipment. One possible cause is the contrast set to minimum.
Sep 16, 2006 | LG Studioworks 440SI 14" CRT Monitor
LG Studioworks 440SI 14" CRT Monitor Logo
102 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
