Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
Disc drive how do I open the disd crive
    Genius:
  • 2,785 Answers
If you want to open the casing then there will be screw in the body of the drive, you have to open the screw
Posted on May 19, 2008
How do I get the disc drive of a dvd recorder to open after getting out the disc and resetting the machine?
Go back through the release process you did the first time to remove the stuck disk. it appears that part of the mechanism that moves the drive did not engage again.
Apr 25, 2015 | Panasonic Televison & Video
Tip
How to slipstream your Windows CD or DVD with updates/ service pack or drivers
Ever wish that when you reinstall windows that it did not require you to install the service pack afterwards or that you would like to include the drivers for your computer already in the windows dics so you just need that one cd/dvd. Many people I know do and all that is needed are a few things.<br /> <br /> Hardware required:<br /> <br /> dvd burner<br /> cd or dvd to burn to<br /> <br /> Software required:<br /> <br /> <a href="http://www.nliteos.com/">nLite</a><br /> Drivers or Service pack (depending on the goal)<br /> <br /> After you download and install the nLite program it is fairly easy to use. Run the application and then select your default language. click next.<br /> <br /> Place your Windows disc in your dvd drive and click browse on the screen then select the optical drive. once this is done the program will ask for a location to store the installation files. Create a new folder on your harddrive and call it Windows or whatever you wish. Clickign next will copy the files to the drive.<br /> <br /> The next screen you will come to after the installation is copied is the Task Selection window. Click on Service Pack if you want to slipstream the service pack to the disc. Click Drivers if this is the goal. There are other options like making the setup unattended (meanig you can put the cd in partition the drive and let it do the rest itself). The last option you will want to do is to make a bootable ISO. The ISO will save to your computer and all your to burn right from nlite to your dvd burner.<br /> <br /> When you do this, you select the service pack location on your hard drive. The same will happen with the drivers. Follow the on screen prompts as you do so and complete the wizard. <br /> <br /> When you come to the "Bootable ISO" screen you have a choice. If this is the only copy of the disc you need you can select Direct Burn from the mode screen. If you want to use this image later you can select "Create image" and follow the on screen information to burn the disd then click Make ISO or Burn.<br /> <br /> After this is all done you will have a Service pack and/or driver slipstreamed Windows Disc. You can also do this with additional updates/hotfixes as well.<br /> <br /> Good luck.
on Jan 20, 2011 | Computers & Internet
Corningware
Yes, according to their website from freezer, to oven to table.
Dec 10, 2013 | CorningWare Freezers
Frigidarie dryer door open
there should be a small switch that senses to door check on sears parts online to see what it looks like
Mar 24, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Standby light swicht on back to standby
Possible errors in the main board , you might have to check the boards for voltage issues inteh controller or the crive section. Please refer my link in the profiles for tips onfaulty conection
Sep 23, 2010 | Orion Televison & Video
Hard crive crashed,
When my hard drive went down a few months ago I bought an external hard drive caddy off ebay for about £13, best £13 pound I ever spent. I installed it into the external caddy, plugged it into the USB port and it worked brilliantly, if the hard drive still doesnt work their are many data recovery firms out there, but be warned they are quite expensive, this usally involves sending the said hard drive off and they send the desired files back to you on a DVD. Hope this helps, Paul
Apr 05, 2010 | Gateway (M520HD80G) Hard Drive
Remove clutch pack on yamaha tw-200
Remove the side cover that the is hiding behind. The pessure plate is like a car, held on by bolts on its perimeter. Remove the pressure plate and the disc can be remove. Remember the first dis is fiber, the next is metal and on and on. You should end with a fiber against the flywheel. Note how the notches on the tangs are arranged. facing out or facing in, aligned or staggared. Soake the fiber disd in motor cycle motor oil for an hour before assembly. If there is an alen screw with a lock nut in the center of the pressure plat, that is a pusrod and will need adjusting after assembly and before the side cover is put on. If so, let me know. Good LKuck,Ned
Nov 12, 2009 | 2005 Yamaha TW 200
I have a 04 chevy avalanche z71. My four wheel crive system wants to try and change from 2wheel to 4 whheel high or low while driveing. Sometimes at start up the red light under the 2 wheel high button...
Have you received any failure codes (check engine light)? If you have, find out what they are by going to any parts store and they can read your failure codes for free. Let me know after that.
Nov 07, 2017 | 2004 Chevrolet Avalanche
My computer is not reading the CD drive
if its not reading the cd drive atoumatcley then open my computer and double click the cd drive icon
Jan 24, 2009 | Dell Dimension 2400 PC Desktop
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
