Question about Whirlpool Refrigerators
Door on both sides of side by side hot - Whirlpool Refrigerators
  • 828 Answers
Heaters in door fames are the effect. Cooling system problem is the cause. Check the condenser for necessary cleaning. Located under front or in back behind removable panel. If condensers are plugged with dust the refrigeration system over heats and can shorten the life of the compressor.
Posted on May 19, 2008
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
Getting cold air only on right side of heater assy, hot air on left side
you most likely have a bad blend door motor, or the actual door is broken inside the heater box. Jeeps used to have this issue, the door shaft snaps and only half will work. If you can turn from hot to cold on the side that's warm, then that's most likely what is going on.
Dec 07, 2013 | 2009 Dodge Journey SXT
My jenn air model # jrsi225 is VERY HOT between the side by side doors how can i fix this ?
Its only natural to feel hot on side doors of the refrigerator. There are heating element that responsible for heating the side doors. Without such heaters, side doors will get moist, wet to touch and then rust will eventually develop causing it to destroy or weaken the refrigerator body, if rust is not treated. You shouldn't worry about that cause that is not a problem.
Thanks for asking.
Sep 01, 2011 | Jenn-Air JSD2789GES Side by Side...
No hot Air on Driver side vent. 2004 W/Truck with
Check the actuator ot the pass side blend door for proper operaton. If it does operate remove it and confirm that the door is not broken.
Nov 03, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Very hot between side side doors.
this unit is working just fine, do not be concerned.
it is part of the condenser side, of the refrigerant cycle, keeping frost from forming around the door seal.
Oct 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
Hot strip between doors
the fan by compressor is not running assuming that the rest of the refrig is ok.
Jun 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hot around the door edges
it have pipes there that the gas are running thru if it doesnt get hot there then you can be conserned
May 31, 2009 | Whirlpool ED5VHGXM Side by Side...
Hot band/divider between doors of side by side refrigerator
That is your external humidity control so that your doors do not get condensation. You are going to have to replace it. Go to repairclinic.com and they have you part
Feb 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The door seal contact surface is hot to the touch.
ther so pose to be a switc if none that for hummit
Jan 17, 2009 | Kenmore 53082 / 53084 Side by Side...
Maytag side by side doors hot
hi there,
you may have a clogged vent, preventing air circulation. is there are vent on the bottom by the crispers?
Sep 29, 2008 | Maytag Refrigerators
Refrigerators Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
