Question about Panasonic SCHT730 800W DVD Home System System
SC-HT75 WON'T POWER UP GIVES A CODE OF F61 AND SHUTS BACK OFF
  • 4,234 Answers
The output amp pac has a problem. The F61 is indicating that the unit is in protect mode. This is a mode where the output section is shutdown to prevent further damage. Figure on $65-$95 for parts.
Dan
Posted on May 19, 2008
MY PANASONIC SA-HT75 KEEPS ON CLICKING OFF WHEN I SWITH IT ON.WON'T START UP
There Panasonic SA-ht75 dvd Decreasing the opening treading on what's happening back immediately shuts down
Sep 05, 2011 | Panasonic SC-HT75 System
My Panasonic SA-HT75 clicks off seconds after I turn it on. Even got a F61 code.
Open the unit and clean/replace the fan.
If it doesn't turn when you power it on after cleaning it, put some oil on its bearing sleeve.
Never power on this device while speakers are not connected!
Hope this solves your problem!
Feb 23, 2011 | Panasonic SC-HT75 System
Unit displays f61 and nothing works What component is related to this
"Check and correct the speaker cord connections. Page 7
If this does not fix the problem, there is a power supply problem. Call 1-800-211-7262 for support."
http://www.retrevo.com/support/Panasonic-SC-HT75-Home-Theater-Systems-manual/id/356ci969/t/2/
It's implying you have a shorted speaker wire.
Jan 22, 2011 | Panasonic SC-HT75 System
At power on, displays F61 code and switches off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C./pre-amplifier circuit is faulty.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 21, 2011 | Panasonic SC-HT75 System
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Feb 22, 2009 | Panasonic Home Theater System System
SC-HT75 home theater
This error means that the unit is in "protect" mode. An error condition was detected in the final stage of the amp and the unit has shutdown to prevent further damage. This is usually the output amp pac that needs to be replaced. Expect a parts replacement cost in the $75-$90 range.
Dan
Dec 04, 2008 | Panasonic SC-HT75 System
Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Mar 24, 2008 | Panasonic SC-HT67 System
Display showing "F61" some electricity failure
you have a problem with speaker cords:-
1-make marks with tape or any marker pen in all speaker cords(left-right-sub- front-rear).
2-after marking remove all speaker cords.
3-insert them one by one until f61 appear.
4-the cord that connected and make the trouble is bad please change it with new one.
Mar 07, 2008 | Panasonic SC-HT75 System
F61 code
yes i did see this code F61  but turned off and back on and the surround and center speakers still don't work
Jan 06, 2008 | Panasonic SC-HT720 System
153 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
