Question about Maytag Refrigerators
Came home sunday night and our side by side fridge freezer was not working, just the fan is running, how do i locate a repairman, since this monday is a holiday. i have frozen buckets of water, and placed bags of ice in the freezer compartment to try and keep the fridge part cooler,and placed the buckets in the fridge side as well, can any one help?
  • carleton730 May 20, 2008
    thanks for the info, however the compressor was extreamly hot, shut it off over nite, and tried again in the morning to no avail. trying to find a repairman, as this unit is still under warranty.
  • 828 Answers
Any frost on back wall of freezer section. If so you have a defrost system problem. If you can hear a hum followed by a click the problem is with the compressor. In back of the refrigerator is a removable panel. remove it and carefully check if the compressor is hot. A cold compressor indicates no power to the compressor which would be related to the temperature control or defrost timer.
Defrost timers are normally located in the area of the temperature controls. Locate the timer and rotate the clutch head screw clockwise slowly until it makes one click. If the timer is the cause of no power to the compressor the compressor will restart. If the problem is defrost related this same action will start the defrost which should take place in 18-22 minutes. If defrost of the freezer coil takes place and the compressor does not restart after the time indicated (wait 30 minutes) rotate the screw slowly one more click and the compressor should restart. If you had to rotate the screw the second time the problem is your defrost timer.
Posted on May 19, 2008
My fridge stopped cooling about a year ago. Freezer worked fine. It was a sunday and I didn't want to extra so I decided to wait until Monday. About 5 hours after the problem began, it...
its your defrost heater or defrost thermostat located on the evaporator coil behind the rear cover panel inside the freezer thats open or bad,if the coil is iced over it cant take cold air from freezer to the refrige via the fan,also make sure this fan is operating too
Jan 21, 2011 | Frigidaire FRS26R4A Side by Side...
Fridge not cooling enough... Repairman said that the board has gone bad but everything works fine other than the fan...Was he just trying to sell me a $400 board or what?
Sounds like either your evaporator fan is bad, or your condensor fan is bad underneath your fridge or your condensor lines are dirty. I would check those things out first.The evaporator fan is located in the freezer behind the back panel. You should be able to here and feel the fan. Good luck!
Aug 20, 2010 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
Side by side kenmore
Have same problem on a 2 month old Kenmore 106.5794*700. side by side.
I can see ice / frost build up behind the lower baffle on fridge side. Does not seem to be any airflow from freezer side to fridge side. Freezer is extremely cold, it is about -23F. I read that 0F would be normal. Fridge side is warmish, running at about about +50F when it should be about +32 to +38F.
BTW: Ice pops started sticking to my tongue, thats why I noticed the unit wasn't working correctly.
I'm not 100% sure but I think the compressor is also running all the time as well. Either that or a Fan or something running. That kinda points to a stuck thermostat or some thing causing it to stick. I suspect that if the Freezer thermostat which is located in the Fridge compartment just may to rely on air flow from the freezer side via a duct, if this duct is blocked, the Freezer Thermostat misread the freezer compartment temperature and will always activate the compressor. Wish I had more details on exactly how the freezer thermostat works.
So after reading various forums on this it looks like a defrost issue causing the ice or frost build up or maybe just a faulty thermostat. Maybe there is a common circuit control board for these two functions?
As this is still in Warrranty I have a Sears Tech coming on Monday 14th Jan 08. I'll be interested to see what he does.
Dec 29, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator is at80 degress
This unit uses the cold air from the freezer to cool the fridge, you will find that the air duct has frozen up, completly defrost overnight with the doors open, this should rectify fault. Regards Advisor
Mar 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
83 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
