Question about Panasonic KX-T7730 Corded Phone
How do i forward calls to an external line please?
Have tried fwd/dnd then 3, 9 (for outside line) then the number, then # but this does not work. Please advise. Thanks, Amira
  • 1 more comment
  • AWillard May 21, 2008
    I have the same problem!
  • Anonymous Jun 07, 2008
    Same problem. Forwarding to other internal stations works, put not to outside line. Same problem trying to transfer to an outside line.
  • Anonymous Dec 16, 2008
I want change the password to external calls
Posted on Jun 02, 2008
How do i forward calls to an outside line on Nortel M7324
You can forward an extension that is not used at all, and has the lines assigned to ring that you want to forward to an outside number. In programming have the extensions set to forward on busy to the external number using 9+ the number desired. When you leave for the afternoon, take the handset off the phone, and replace it when you return. NOTE THIS EXTENSION MUST NOT BE USED BY ANYONE -- IF THIS EXTENSION IS BEING USED AND A LINE RINGS IN IT WILL BE FORWARDED OUT.
Mar 19, 2013 | NorStar M7324 Telephone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 '
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    When i press the program button and FWD/DND buttons nothing happens
    You have to set the button up first. You can press the FWD button (or press INTERCOM and dial *710) then x (500 or 165 for your voice mail) #, where x is 2 for all calls, 3 for busy, 4 for no answer and 5 for busy/no answer. That will set the FWD for calls. To set DND, dial *7101. Once you set those codes, your FWD/DND will toggle between the 3 steps of OFF/DND/FORWARD.
    *7100 cancels the button. These are the codes for All calls. There are 711 and 712 codes for internal and outside calls if you need to split them. Also, the No Answer and busy timer can be adjusted by the *713yy command where yy is the number of seconds. A good number is *71324 which gives you about 4 rings.
    This is explained in you phone system Operating Manual (OM) under Call Forward and Do Not Disturb.
    Aug 24, 2011 | Panasonic KX-T7630 Corded Phone
    I have Panasonic KX-T7420s with a TVS50. I have voice mail set up at each extension number. I tried calling from an outside number and transferring to a different extension number to see if I can leave...
    Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
    If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE should adjust that to no more that 4.
    Dec 27, 2010 | Panasonic KX-T7420 Corded Phone
    I need to turn of fwd/dnd
    Take the handset off the hook, then press the FWD/DND button followed by 0 (zero). When you hear the tone, hang the handset back up. This will work with the PT (Panasonic Proprietary telephone) system. (Alternatively, pick up the handset, press 7 (seven) 1 (one) 0 (zero) 0 (zero) and hang up after the tone. This works for PT and SLT phones (single line telephone))
    The same sequence works to cancel call forwarding (except for follow me forwarding). In the Follow me mode, pick up the handset, press FWD/DND or 7 1 0 followed by 8 and the extension number. Then hang up after hearing the tone.
    I hope this helps.
    Sep 23, 2010 | Panasonic KX-T7130 Corded Phone
    How do I divert calls to a mobile number and then undivert calls
    pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
    What 2 does it turn on the call forwarding feature
    . and 0 turns off forwarding/do not disturb functions
    theres 5 different functions after you press FWD/DND
    0: turns FWD/DND off
    1: put the phone into Do Not Disturb Mode
    2: call forwarding
    3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
    4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
    and lastly 5: Busy/No Answer- does both function 3 & 4
    i hope i've helped
    , Cameron
    Jan 22, 2010 | Panasonic KX-T7630 Corded Phone
    The behavior of the FWD light is programmed in system options. By default, it's usually set to be solid on FWD and blink on DND.
    Here's a quick cut and paste from the OM for 76xx phones.
    Dial *7x0y Where x=1-3 and y=1-6 for the following conditions:
    Do Not Disturb *7101 / Cancel *7100
    Call Forwarding (FWD)
    – Both Calls *710
    – Outside Calls *711
    – Intercom Calls *712
    2 (All calls) + phone no. + #/
    3 (Busy) + phone no. + #/
    4 (No Answer) + phone no. + #/
    5 (Busy/No Answer) + phone no. + #/
    7 (Follow Me) + your extension no./
    8 (Follow Me Cancel) + your extension no.
    So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
    Sep 14, 2009 | Panasonic KX-T7633 Corded Phone
    Panasonic kx-t7030 FWD/DND button
    Outgonig calls and the FWD/DND button are not realted. Walk up to the phone and dial 790 on the intercom. That should reset everything.
    Now, try that calling out and see what it's doing. If you can dial "9" from the intercom and get an outside line, start dialing a number and see if it fails. Watch the display at all times. If it is still broken, post back.
    Jun 23, 2009 | Panasonic KX-T7030 Corded Phone
    We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
    Panasonic KX t7730 call forwarding function to external party:
    If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
    If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
    lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
    Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
    Call forwarding to another land line number
    When I need to leave my office unmanned, I take my calls with me. Just pick up your receiver, hit fwd/dnd button, then punch in 69 and then the number of your landline and then the pound sign. When you no longer need them to be forwarded, hit the fwd/dnd button and then 0
    Jun 08, 2009 | Panasonic KX-T7431 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    219 people viewed this question
    Top Panasonic Lands Phones Experts
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
