Question about Lexmark X6170 All-In-One InkJet Printer
Lexmark X7350 alignment problem
I just tried to replace the black ink cartridge on my Lexmark X7350. After replacing the cartdrige it keeps saying that there is an alignment problem & that I should remove the tape from the cartridge, despite there being no tape anywhere on the puppy. What should I do? Any sound advice?
  • 5 more comments
  • paulbh1 Dec 18, 2008
    Frustrating as hell! I thought the problem may be the new cartridge so I tried another new cartridge but got the same result. I even tried the cartridge I just replaced and got the same result, which makes no sense since I was not getting that error with the original cartridge......
  • trucker49979 Dec 21, 2008
    it is telling me that the tape needs to be removed . i have taken the cartiridges many times and put back in. i also have a second problem of the color not printing out. i recently also replaced the color aabout two before replacing the black.
  • Anonymous Jan 26, 2009
    I have exactly the same problem - A message says I have an alignment problem, the black prints blurry and blue will not print at all. I have not tried a new cartridge because I am afraid it will give me the same problem, and I would rather put that money toward a new printer unless I have some assurance that it will solve the problem.
  • dkharr Jan 26, 2009
    I have exactly the same problem with an X5250. A message says I have an alignment problem, black prints blurry and blue will not print at all. I don't want to waste money on new cartridges unless I have some assurance it will solve the problem, because by the time I spend that much money, I could almost buy another printer.
  • Anonymous Feb 27, 2009
    I have a Lexmark x7675, brand new and I just installed. I am also getting an "Alignment Problem" notification because the color ink is not printing correctly. My problem is the blue ink will not print at all. I contacted Lexmark phone support and they tried to help me through everything you could think of, i.e. cleaning the cartridge with a damp cloth, unpluging, etc. but still having the same problem. They are sending me a replacement cartridge so hopefully this will work. Will keep you posted.
  • tnt73 Mar 01, 2009
    I have the same problem. I just replaced the color cartridge and it is saying color cartridge is missing. HELP!!
  • dussepa May 25, 2009
    I have the same issue, changed the black cart and now the printer reports an alignment error.
    Genius:
  • 2,785 Answers
You can check the old cartridge for reference
Posted on May 19, 2008
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
How to change the black ink cartriage
User guide available for free from here
http://www.intel.com/support/chipsets/sb/cs-009236.htm
Go to page 69 for clear instructions
Mar 06, 2011 | Lexmark X7350 InkJet Printer
Alignment problem. just refilled black ink cartridge..seeing message that printer is not aligned and remove tape from cartridge, but i see no tape
1) remove the cartridge and check it is not leaking. If it is, the printhead area on cart will be flooded with ink. Removing couple of ml from cart will stop it leaking.
2) If the cart looks clean (not leaking), stamp the printhead on some folded tissue paper or paper towell. It should leave a solid black stripe about 10mm long on the tissue. If it doesn't, your refill ink hasn't quite reached the printhead. You can blow little air into the breather hole (on top) to prime the printhead. Stop blowing when ink starts leaking at the printhead.
Clean the cartridge up before installing it.
3) If all above is ok and it still doesn't align properly, repeat above steps with the colour cartridge. The printer needs all colours working to perform the alignment process.
good luck with it
LC1000
www.inkbank.com.au
Dec 10, 2010 | Lexmark X7350 All-In-One Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
Alignment Issue
Browse through the menu, there must be a head alignment test/function. Also inspect the printer driver and/or utilities installed on your computer and find a head alignment function.
It's not complicated, either it's fully automatic, or you'll have to look at a printout and choose the best-aligned lines, depending on printer model.
Nov 01, 2009 | Lexmark X7350 All-In-One InkJet Printer
Please send me e-mail with answer. Need to know what cartdriges black and color for my Lexmark X5495 Thanks
The Black cartridge # is Lexmark # 28A (18C1528)
The Color cartridge # is Lexmark # 29A (18C1529)
The High-Yield (more ink in cartridge) Black cartridge # is Lexmark # 34 (18C0034)
The High-Yield Color cartridge # is Lexmark # 35 (18C0035)
The Photo Color cartridge # is Lexmark # 31 (18C0031)
Sep 18, 2008 | Lexmark Office Equipment & Supplies
Ink Cartridges
You should be able to open the printer below the scanner. The printhead should move to the center of the printer. Then you open the clips holding the cartridges and remove the old. Replacement cartridges click into the same slots. Then you secure the clips and close the printer.
Jan 28, 2008 | Lexmark X7350 All-In-One InkJet Printer
Lexark X7350
If the contacts are different, then you may have bought a damaged cartridge, or just simply the wrong cartridge and this would explain why your printer cannot recognise the cartridge. Make sure you bought the same number Lexmark cartridge as the old one. Return it to the store as a damaged cartridge if it is the exact same cartridge. Lexmark would not change the design of a working cartridge to exclude customers from using a printer.
Sep 07, 2007 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
3,302 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
