Question about Zebra 105Se Thermal Printer
Zebra 105Se missing line
Hello all,
from time to time, one line of information is missing when printing a label.
Does anybody know the reason.
We see in the log files, that correct information has been sent to the printer.
Thanks for interest.
  • lianchang_mo May 20, 2009
    I have the same problem with Zebra 100XiIII Plus.
  • Zebra Master
  • 2,794 Answers
Try cleaning the thermal printhead. Zebra makes thermal printhead cleaners or you can use a qtip and some isopropyl alcohol.
Make sure the printer is turned off before doing this.
Posted on Aug 25, 2008
2 Suggested Answers
  • 45 Answers
SOURCE: Missing lines 105SE
If you print too close to the top or bottom of the label, the printer might remove the whole line reather than print part of each character.
If the missing line is somewhere else, the printer might be using a "cached" image. If your software has a feature like "Clear Cache" or "Reimage Label", you could give that a try.
If this doesn't work, let me know the type of software you're using and I'll try again. :-)
Posted on Sep 18, 2008
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
Jun 04, 2014 | Zebra 105Se Thermal Printer
Zebra 105se printer is printing out of the label on the wright side
re donload software for it maby firmware update cheak settings in software ok
Feb 02, 2008 | Zebra Z6M Plus Thermal Label Printer
Skipping labels
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
You can clean the sensor with an coton cloth dampened into isopropylic alcohol.
Here is the link to user manual:
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Nov 27, 2013 | Zebra 105Se Thermal Printer
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
My zebra 105se printer got move to a different location and now it is printing very slow. Is there a way to set the speed faster?
Our company is an authorized reseller for Zebra printers, as well as labels & ribbon. You can adjust the speed and heat settings on your zebra printer, however your labels software will often override any settings. What software are you currently you using? If you can let me know, i will tell you how to change settings in your software- which will override the print to print faster.
Conti Systems
Bethany Miller
972 870 9400x105
www.contisystems.com
bethany@contisystems.com
Feb 15, 2011 | Zebra 105Se Thermal Printer
I am using a Zebra 105SE printer. When I print labels, I can not get the text to start at the top of the label. No matter what I do, the text starts half way down the label.
Label position may be off. Power on while pressing the cancel key for 10 seconds. This should print a configuration label. Use large label for this. Check the parameters, specifically top position and tear off position. The default is 0. You might also check the main drive belt for stretch or missing teeth. You need a user manual for that printer because there is no lcd panel. It is not user friendly without manual.
Nov 11, 2010 | Zebra 105Se Thermal Printer
Our Zebra 105se printer has started missing labels. For ex., it will be printing a batch of 40 and every third or fourth label it shoots out an empty. sometimes it puts out two empty labels but in the end...
Clean your platen roller. It's the white rubber roller (that turns and pulls your labels through your printer) located under your printhead. When this gets slick it causes your labels to slip while printing.
You should use rubbing alcohol to clean it. Your computer guys may also have some cleaning wipes in a foil packet that you can use.
Jul 13, 2009 | Zebra 105Se Thermal Printer
Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
May 30, 2008 | Zebra 105Se Thermal Printer
Missing lines 105SE
May 19, 2008 | Zebra 105Se Thermal Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
192 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
lancer284
Level 1 Expert
kenneth njonjo
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
