Back to:
Tags:
Air Conditioners
Generic problem for all Air Conditioners
Air conditon units
posted by swadow on May 19, 2008
what does seer mean to me when buying air conditioner tons I understand is amount hold i have a 3 ton now and getting told so many different answers I am being told I should go to 4 ton and higher seer others saying keep 3 and go a little higher seer can you explain thank you
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 20, 2008
FixYa! (100)
fixum1
Rank:Guru Guru
Rating: 88%, 483 votes
the higher the seer the more efficent it is no matter the tonage of the unit
make sure that the tonage is correctly sized for the home rule of thumb is if the home is insulsted properly 600 sq feeet per ton
oversizing creates shot cycles real cool then warm real cool then warm, under size unit runs all the time
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on air conditon units:
I don't want to Accept this solution
Can you Help with these Air Conditioners problems?
Frigidaire FAC125P1A 12,000 BTU Window AC...
this will be replacing an older unit. any info will be...
Air Conditioners
I have just bought a house that has a Carrier furnace, it...
Air Conditioners
I have a carrier A/C in my home. There thermostat went out...
Air Conditioners
I have a Carrier Furance model 58GFA and I have removed...
Air Conditioners
I have a Weatherking Acclaim II furnace and the burner...
Loading problems.
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
