Question about Panasonic Lumix DMC-FZ20 Digital Camera
Lens filter size.
Filter thread diameter required for Nikon, FF-CP10 NC (Neutral colour).
Camera Manual does not give this figure (24mm to 85mm equiv). Please assist. I have a panasonic dmc 20 need to know filter size looked everywhere
The filter size for the FZ20 is 72mm.
Posted on Jul 13, 2008
I have just purchased polaroid lense filters polaroid say they are compatible with Nikon d90 but I cant get them on do I need something else to attach them
Filters must be the right size for each lens. For example the 18-105mm kit lens that comes with most D-90 kits uses a 67mm filter. They thread into the main lens. It is always safer to put a clear or UV filter on your camera lens to protect the expensive lens glass. You can thread another type of lens onto it as easily as you can your base lens. Be sure and do not force a threaded lens filter onto your lens or you will damage the expensive lens. It should thread on easily and do not over tighten it.
Dec 12, 2014 | Nikon DSLR D90 Digital Camera
Dear sirs; What type of uv filter fits a quantarary tech 10 28mm - 200mm zoom lens. I have several 62mm filters and the zoom lens does not accept the normal threaded screw on format common to lenses
First, make sure that the lens diameter is 62mm. It should say on the front or on the body of the lens. If this is correct, it could be a unique mount that would require a specific brand. If it's quantaray, it might require quantaray filters. If it's an old lens, it might require an attachment to the front of the lens that would act as a filter holder for the square filter tiles.
Jun 04, 2012 | Cameras
Would a hoya Infrared R72 filter tamron 72mm lens
That would depend on the filter.
Since Tamron has never made a lens with a fixed focal length of 72mm, I assume the 72mm is referring to the filter thread. I also assume you mean the Hoya RM72 infrared filter. The "72" in the filter name is a description of the filter and has nothing to do with its physical size. One vendor lists the RM72 filter in sizes ranging from 46mm to 77mm. As long as you get the filter to match the thread on the front of the lens then it will screw right on.
May 29, 2012 | Hoya 72mm RM-72 Infrared Filter
What size of filter works with this lens
If you mean the Sigma 50-200mm f/4-5.6 DC OS HSM lens, then it uses a 55mm filter. The lens should give the filter size somewhere near the front. You can also take a ruler and measure the diameter of the filter mount.
Jan 04, 2011 | Sigma 55200mm f456 DC Lens For Sony...
How do I fit the Hoya UV filter that I have been sold with my New Nikon D3100?? Darent be too heavy handed as new to this. Thanks.
The filter doesn't go onto the camera, but onto the lens. Assuming it's the proper size, it should just screw into the threads on the front of the lens (the end away from the camera). If the lens hood is on, remove it first.
Nov 07, 2010 | Nikon Cameras
Will the Rokinon 85mm 1.4 lens autofocus with the Nikon D90?
No!
The Rokinon is like the Nikon 85mm AIS lens and is manual focus only..
Hope this helps, Andrew
May 07, 2010 | Rokinon 85mm f14 for Nikon
I HAVE A SIGMA 600MM MIRROR LENS , WITH A
The nominal filter size of the Sigma 600mm F8 Mirror lens is 30.5mm(Rear).
The actual filter has a rear screw thread measured across that is approx 22mm.
Does this look like what you have?
If you look for Sigma 600mm mirror filters on the web you may find some.
As you can see by the photo the filters are mainly for film use.
Feb 02, 2010 | Sigma Super Telephoto 600mm f/8.0 Mirror...
How do i remove the front group from a 24mm/2.8 AI nikkor lens? i have removed the name ring, but there are no spanner/wrench grips around the front group. thank you!
The filter cup, which you removed the name ring from, needs to be removed as well. It has a small set screw near the focus ring that retains it. Remove the set screw and the filter cup can be removed.
Nov 25, 2009 | Nikon 24mm f/2 Nikkor AIS Lens
Dont know where filters go for Quantaray mirror lens 755035
That lens takes a 77mm filter - if you examine the end of the lens very closely, you'll see some threads just on the inside lip of the very edge - the filter screws on to the end via those threads.
Oct 22, 2009 | Quantaray 500mm f/8.0 Mirror with Macro...
What size filter do I need for a Nikon D40 and what size filter do need for aSigma 70-300mm Thank you
Hi!
Usually the diameter is written on the front of the lens. You can use lens with different diameters on this camera, it really depends on the lens, but it will most likely be a 58mm.
Tom
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Panasonic Lumix DMC-FZ20 Digital Camera Logo
99 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
