Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power light flashes 3 times
I own a 52 inch rca hdtv model # d52w20 When turning the tv on the power light would flash 3 times and the tv would not come on. After many attempts the tv would work that lasted for about 3 weeks now it just flashes and does not come on. This happened once before and the tech replaced the power transistor and fly back. I ordered a fly back and will try that any other advice would help.
Thank you in advance,
  • 5 more comments
  • Shock216 May 22, 2008
    the fly back did not fix the issue I ordered a Horzontal out put Transistor. I hope this fixes the issue. Any feed back would be helpful Thanks in advance.
    The High voltage Transistor did not fix the issue so I did check the connections on those coils. I found 3 green caps 2200 mf16v 22035v 33035v bulging out the top and bottom I pulled those caps and turnd on the tv now I get a high pitch sound instead of a low pitch sound when trying to turn on the tv. I ordered these caps and am pretty sure that this is the last fix I will keep all posted Any feed back you can offer is helpfull and thanks for the help you have already given. Thanks in advance.
    Shock216
  • rich697795 May 23, 2008
    i have an rca hdtv d52w20b the power light blinks have to hold the power button down to get it to turn on but once on works fine can turn in off then back on with no problem but if ts off more than an hour i have to hold the button down again to get it back on
  • CURIOUS G May 23, 2008
    SAME THING THE OTHERS HAV LIGHT BLINKS 3 TYMZ NO TV!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
  • Shock216 May 24, 2008
    I fixed it the capacitors worked. Thank you all for the support.
    Shock 216
  • STAYHOMEMOM May 27, 2008
    RCA D52W20
  • mcgregor11 Jul 07, 2008
    I have the exact same problem.  I assume this something that a tech has to fix?
U CAN THRO THE ******* THING BACK AT THE ******* PEOPLE WHO MADE IT!!!!!!!!!1 I GOT THE SAME ******* PROUBLEM AS THE OTHER GUYZ!!!! BUYING A **** N SONY NEVER AGIAN A RCA ********!!!
Posted on May 23, 2008
  • RCA Master
  • 8,617 Answers
The flyback should cure your problem.
Posted on May 19, 2008
  • Sonny Berry
    Sonny Berry May 22, 2008
    If the flyback didnt fix that issue locate a small plastic coil with copper wire wrapped around it. check the solder connections on that it is within an inch or two from the flyback its usually white or black plastic tower with exsposed copper wrapped around it.
I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power...
On Deflection board CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad their is 2 more caps in same circuit replace them also cp114 cp120 220uf 35v also resolder all pins on FBT flyback Transfomer
Nov 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light flashes
Same thing here....RCA tells me to count the times the light flashes as it apparently is set to "tell" you what the problem is.......3 to 5 flashes means your lamp is messed up.....they are over $300 to replace!
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
more than likely the sony has a bad flyback
It is available from
www.electronix.com
Thanks Guy
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
580 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
