Question about Panasonic Office Equipment & Supplies
UF-6100/series Meter/Life Counters
Is there anyway of taking a meter/life counter reading from this serieas of fax machine?
drichards
  • 87 Answers
SOURCE: CANNOT FIND METER COUNTER ON MACHINE?
Print a configuration page. It will be on there. Menu, lists/prints, config page.
Posted on Feb 23, 2008
Cogz
  • 1326 Answers
SOURCE: How to read the meter on Cannon Copier
Yes, that is the correct counter of the copier. If you are doubting it, you can look at the bottom right of that display and confirm that the serial number is the same as on the back cover of the copier and also, it well tell you the model of the copier aswell. It is kind of hard to fake the meter or change it to a lower amount. To do it you need to change 3 PCB's from another copier & it is more work to bother with.
Posted on Nov 07, 2008
daryn720
  • 113 Answers
SOURCE: flashing red lights, with error message - service required
THESE PRINTERS ARE CONSIDERED BIC LIGHTERS IN A TECH'S WORLD BUT YOU COULD TRY RE-SETTING IT AND OR REMOVING ALL SOFTWARE AND RE-INSTALL FROM SCRATCH.
Posted on May 07, 2009
57 varieties
  • 1653 Answers
SOURCE: Reset Counters
There is no known way to do this!
Posted on Sep 11, 2009
  • 24 Answers
SOURCE: How do I reset the counters for drum life?
You must order a fuse from a toner supply company.
Ask for instructions but it is not a easy task. I pay someone to do mine.
Posted on Feb 24, 2010
How to reset the counters of the dev unit of konica minolta c360
The developer unit has been reset automattically,after change the old unit another new.You can change the developer unit life STOP after 45000 copies or NOT STOP more 400000 copies.To change the unit life press:
Utility - Meter count - Check details - Stop - 0 - 0 - Stop - 0 - 1 -Stop - 0 - C - select IU life stop setting touch NO STOP.
Aug 06, 2013 | Office Equipment & Supplies
The machine says "replace ozone filter" i did that but the message won't reset itself. is there something i can do to reset it?
On most models of Color Bizhub machines, to reset the ozone filter message you must go into service mode. Press the Utility/Counter button on your operation panel, select meter count, then detail, press stop,0,0,stop,0,1. This will put you in service mode. Find and press counter button, Locate life counters, and clear ozone filter. You will not be able to clear some of the counters in this menu. They are automatically cleared when the items are replaced.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
Have a Panasonic Fax/Printer model DP-2310 where do I find the meter reading?
open the door where the toner is and on the left you will see a counter that is your meter reading
Apr 22, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I need to replace the Ozone Filter on our BizHub C351 but I am not spotting where it is hiding on the machine? Any clues to lead me to the right spot?
go into service mode. Press the Utility/Counter button on your operation panel, select meter count, then detail, press stop,0,0,stop,0,1. This will put you in service mode. Find and press "COUNTER" button, Locate "LIFE COUNTERS", and clear OZONE filter. Always remember it, have a good time.......
Mar 23, 2010 | Konica Minolta bizhub C351 All-In-One...
How do I get a meter read from Panafax UF-560
Press
Function
7 monitor key slowly 4 times
* asterisk
set
16
set
counter on 2
set
stop stop
Function 64
set
look at the printout.
Oct 20, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
How do I get the meter or counter reading for Panafax UF-8000
Press
Function
7
set
2 for on
STOP
STOP
Now
press
function
64
set
look at the right side of the print outs for the numbers.
Sep 29, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Meter or counter reading
press function,7, monitor ,monitor, monitor, monitor (that's 4 times). Then press the star key. press 3 then the down arrow twice and then start. That should print a report showing the page count.
Apr 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Konica 8020 color copier: image transfer roller unit needs to be replaced , Replaced but it is not able to recognise the change
Because you have to go into service mode and clear the counter.
Utility then meter count then stop00 stop01. then touch counters then touch life clear the transfer roller.
Sep 08, 2008 | Konica Office Equipment & Supplies
Need to know how to reset codes
To reset the life counters for the transfer roller & ozone filter you will need to enter the service mode.
To do this press utilty, meter count,details(if available), then stop, 0, 0, stop , 0, 1.
You should now be in tech rep mode, select counters then life.
Select the transfer roller/ozone filter button and press the C key on the keypad.
It should zero the life count.
Now press end, exit etc until you back at the copy screen.
Warning: Please do not reset or clear any other data within tech rep mode or you may inadvertantly affect the performance of you machine.
Hope this Helps.
May 05, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Sep 19, 2007 | Office Equipment & Supplies
32 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
