Question about SanDisk Sansa m230 MP3 Player
Mp3 when i power up my mp3 player, it turns on for a second and a powering down message appears and it turns off. the same applies when i connect it to a computer (the computer does not recognise it).Please help me.
  • 1 more comment
  • Anonymous May 19, 2008
    my sandisk mp3 wont turn on at all, i put a new battery in it and it still wont turn on. i plugged it into my computer and the computer didnt recognize the mp3 what do i do?!!?
    my sandisk sansa mp3 is broke, it wont show the battery life, how many songs are on the mp3, or if the songs are on repeat, then the mp3 just shut its self off. it wont turn back on and ive but in a new battery it still wont turn on. and i plugged it into the computer and it dont recognize the mp3.
    what do i do?
  • toym0418 May 21, 2008
You probably need a new battery...
Posted on May 24, 2008
Check the battery strength......
Posted on May 19, 2008
My sansa san disk mp3 player wont turn off when not connected to pc. when it is connected it keeps going from saying connected, disconnected and writing all in seconds. when it is connected to the pc it...
First lets try resetting your player, to reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Next; if that does not help click on this link and down load the Updater program and update the players firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156
Oct 16, 2010 | SanDisk Sansa e260 MP3 Player
Sony Walkman Atrac
Have you tried to reset the player?
Jul 18, 2008 | Sony NW-HD5 MP3 Player
It Keeps Freezing up and i want to know how to fix it
Try this - Reset the device 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Or you can try to force MSC modes 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC. If none of this helps you might need to reload and update to the latest firmware or try and force recovery mode. 1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off. 2. Slide the Hold switch so the orange portion shows. 3. On your PC, double-click My Computer 4. On your Sansa player, press and hold the REC button while connecting it to the PC. 5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer. This may not work on your player not sure of the Model cut off.
Jan 16, 2010 | SanDisk Sansa Clip MP3 Player
How to unlock sansa 1 gb mp
Sansa Connect No-Wifi Recovery Tool
Make sure your Sansa Connect player is charged and the HOLD switch is in the unlocked position. Press and hold the power button for 20 seconds, then release it. This will force the Sansa connect player to reset and restart.
If your player still will not start after trying the reset, you may need to run the Sansa Connect Recovery application.
With a copy of the Sansa Connect Recovery application installed on a PC, you can connect your to the device via the USB cable to the PC, and restore the device software to an uncorrupted state.
However, all of your subscription settings and content will be removed from the device.
STEP 1 - Download and install the recovery tool.
STEP 2 - Put your Sansa Connect player in Recovery Mode
1. Press and hold the Power button for approximately 8 seconds to turn off the player.
2. While holding down the Right button, and Volume Up Button,
press-and-release the Power button. Keep holding the Right and Volume Up button. After a few seconds, the player will start and a Recovery Needed message will on the player's screen.
3. Connect the player to a PC.
4. A SanDisk Device Recovery dialog box will appear on your PC. Choose Recover Sansa Device and click OK.
5. Follow the steps in the SanDisk Device Recovery application.
Hope this will help you.
Jan 02, 2010 | Audio Players & Recorders
Frozen
http://www.sansa.com/support/sansa_e200/faqs
Question 9 from the Sansa FAQs gives these instructions:
Applies to the following Operating Systems:
  1. Windows XP, Vista
The player might have a power glitch. As a result, it does not turn on and is not being detected by the computer.
STEP1 - Reset the player
  1. Hold down the Power button for 20 seconds, then release.
  2. Run the hotfix.
STEP2 - Connect the player to the computer
  1. Connect the device to the computer
  2. Once the device responds, disconnect, and turn it on.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
Mp3 froze
From the Sansa FAQ page at http://www.sansa.com/support/sansa_e200/faqs
09. When I turn on my e200, nothing shows but the blue ring is on, what do I need to do?
  2. Run the hotfix.
Jan 04, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Can u help pls
1) Hold the power button (slider) in the on position for about 15-20 seconds to force the player to turn off, if it's already on.
2) Hold the menu button down and simultaneously hold the power button (slider) to the on position.
3) Do not let go when the device turns on. You will then get a screen message in black and white that reads (with a typo):
WARRING !!!
NAND FLASH MEMORY INITIALIZE......
"WARRING !!!" will appear in red (and probably should read "WARNING". You will have the options of "No" and "Yes".
4) Choose "Yes" to re-format your device.
Jul 09, 2008 | Insignia Sport MP3 Player
Cant dectect the player
WARRING !!!
Feb 07, 2008 | Insignia NS-DV2G MP3 Player
Frozen screen
Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again.
Make sure there's a battery in the player. This doesn't work when it is plugged into the USB port.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
