Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
Removing bad secter from hdd
I have a 10 hard disk of samsung comppany
but all hardisk have bad sector .
how can i remove bad sector from hdd
    Champion:
  • 207 Answers
There are vaious ways
if u know how to make it slave hdd make it one by one on any desktop and run a disk defrag and scan along wd the consistancy check it is a time consuming process
ill suggest to format them it will take 20 min/hdd
Posted on May 19, 2008
How to repair samsung HD502HJ bad sector
No way. Try to make it shorter and cut off that area including bad sectors. Make a two partition around and enjoy!
Feb 11, 2014 | Samsung HD502HJ Hard Drives Sata-ii...
My 40gb disk drive show error in system boot process, but after some time available in system bios. i was installed xpsp2 just 2 day ago and today it was corrupted. what i do ? please help me.... Sandeep...
Well i think you have bad secters in the hard drive,
try doing a defragment on the hard drive,
but thats the way a hard drive goes when it has bad sector in it,
see if you can get an other drive for it, ebay
Nov 20, 2010 | Samsung 40 GB ATA133 Hard Drive
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
My computer HDD have bad sactors please help to remove this on
When a hard disk has bad sectors, these sectors can be fixed by running check disk. This is a temporary fix as the hard disk is nearly worn out and it will get more bad sectors and evenually the hard disk will fail completely.
Bad sectors occur when the magnetic oxide on the disk platters is worn out and data cannot be written or read from these sectors.
To run check disk click Start - My Computer - right click on C Drive and click on Properties - click on Tools tab - then Check Now in Error Checking
I suggest once this has been done, you back up your data and purchase a new hard disk ready to install Windows etc. when the hard disk fails completely. You may want to install a new hard drive before the old hard drive fails completely.
Aug 21, 2010 | Western Digital Caviar SE WD1600AAJS 160...
How to remove bad sector in HDD ???
If you are a professional you can use two programs or softwares to remove bad sector from any hardware.
1. Hard Disk Regenerator
2. Spin Write
100% guaranteed it will work to repair them or some time remove bad sectors from hard disk and your hard will work so better and fast like a new hard disk.
Good Luck
Dec 16, 2009 | LaCie (300770) 250 GB Hard Drive
Remove the bad sector from samsung sp0411n
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
Jun 03, 2009 | Samsung (SP0411N) 40 GB Hard Drive
How to remove bad secters
You can't delete / remove bad sectors, they're faults on your hardware. Once you have a few bad sectors, you can be sure that your disk won't last any longer. My advise is to backup now your important files.
Feb 17, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Harddisk fault
Hello!
Just try scandisk, Right click your c: and then properties, in tools menu, click check disk or scandisk.
may this help.
melnavz
Mar 03, 2008 | Compaq Presario 5000 PC Desktop
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Hardisk pro
You cannot recover bad sectors. Your disc is damaged and the drive has removed the bad sectors from being writable. You need to replace your hard drive asap before it breaks entirely. You're going to lose all your remaining data on the disc if you do not back it up immediately. Good luck, Peter
Aug 06, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
303 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
