Question about Fisher and Paykel AeroTech Double OD302 Electric Oven
Oven not working
We have a F&P electric oven. The oven has stopped functioning suddenly. It doesn't light up and the indicator light of the temparature panel also is not lighting up. Hope somebody can suggest some solution. Thanks.
Tomso
  • 3 Answers
In this case, I would check the following:
  1. Make sure the oven is receiving power. Turn the power off and on at the circuit breaker.
  2. Pull the oven out of the wall and inspect the control boards. Look for burned areas. The power area could have burned out or the control card probably burned out.
  3. Personally, I think that in this case, the are that the whole computer card will need to be replaced. It runs over 100$ in parts.I think this because it's happened twice to me -- once when we had a power surge in the house, another time when I simply replaced a light bulb in the oven.
I hope you will post back what the actual solution was.
Posted on Dec 28, 2008
My Prestige PR1 S0 oven suddenly stopped working. I checked the socket it was plugged into. No power when other electrical item (radio) is plugged in. I plugged the oven into a gang socket which was...
It sounds as if the oven element short circuited and tripped the oven circuit. You will need to reset the oven circuit breaker or rewire the fuse at the switchboard.
If the oven indicator light comes on when you turn the oven on you will need to replace the faulty oven element.
Feb 23, 2011 | Ovens
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Dec 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
U1721 Strange Problem
could be a clock fault - try bypassing the auto function on clock.
otherwise, check the terminal block where mains is connected. these quite commonly burn out
Jul 06, 2008 | Neff U1721 Double circotherm Electric Oven
Zanussi ZBQ 965(X) Built-in Oven
Sounds to like the oven element has gone, the red light indicates that power is going to your thermostat o/k.
Check the oven element.
Nov 16, 2007 | Zanussi ZBQ665 Electric Single Oven
Electric oven
was there a lightening storm (that may have zapped the micro-controller chip) prior to the problem?
May 06, 2007 | Maytag MEW5530D Electric Single Oven
Open Questions:
See all Fisher and Paykel AeroTech Double OD302 Electric Questions
Fisher and Paykel AeroTech Double OD302 Electric Oven Logo
454 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
