Question about HP Compaq nc6320 Notebook
Dip switch positions for cmos reset please - HP Compaq nc6320 Notebook
  • Anonymous May 24, 2008
    hi,got this travelmate 283xc cheep,not working, want to know if dip switch is set correct, dont know the settings can u help. cheers sujoy999
  • Anonymous Jun 11, 2008
    Dip switch setting for CMOS reset required. I tried all 4 seperately with no effect. What method should be followed? e.g. Set switch three on. Power on. Power off. Set swithch three off. CMOS resetted. ??
Where are they located cant find anywhere
Posted on Jul 20, 2008
    Scholar:
  • 105 Answers
We have slightly different model and series numbering for Acer laptops here in UK. I have checked the service manuals for both the travel mate 270 and 290 series. Neither of these has internal dip switching - THE ONLY INFORMATION i CAN FIND FOR 280 IS THAT NORMALLY ALL FOUR SWITCHES ARE OFF AND SWITCH 3 IS USED TO RESET BIOS AND PASSWORD. I hope this helps - please be sure to rate this mail. Thanks......
Posted on May 28, 2008
  • 121 Answers
The cmos jumper which is usually located near the battery has
2 position one is short and the other is opened . its not possible for the system to start if its short at the same time no damage will occure if the system is started while its short.
so whenever the system starts then the jumper is set right.
2 Suggested Answers
Sandy4u
  • 107 Answers
SOURCE: dip switch positions for cmos reset
Hi.
there is no any dip switch for reseting COMS
if u want to reset coms u need to disconnect u r laptop battery & then disconnect coms battery from motherboared witch under keypad .then get press powre button for 30 sec.for discharge static charge of u r motherboard .after that u connect all this to u r laptop u get reseted COMS
if this information is useful for u please Rate me................
Posted on Jun 19, 2008
Remove bios password
On the computer motherboard locate the BIOS clear or password jumper or dip switch and change its position. This jumper is often labeled CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD, PSWD or PWD. To clear, remove the jumper from the two pins currently covers the replace it over the other two.
How to clear an unknown BIOS or CMOS password
How to Reset BIOS Password
Lost BIOS password Resetting the BIOS
Dec 18, 2015 | Computers & Internet
Reset bios password
in desktop computer this can be done by shorting cmos reset dip switch or removing cmos battery momentarily for a couple of seconds or minute at least. If you are working on a laptop computer the location of the dip switch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Dec 03, 2013 | Dell Inspiron 8600 Notebook
Can I program a 10 dip switch remote to replace an 8 dip switch remote?
You should be able to, 8 dip switches gives you 256 addresses, the 10 dip switches gives 2048 addresses, just leave switches 9 and 10 in the off position and set the switched the same.
Jun 16, 2012 | FireFly 300mcd21k - 1 Button Keychain...
Mark 100 has a
I removed the control panel and saw that it had a series of dip switches. All these dip switches were all positioned to the same side, this is the way it was installed.
I reset it by flipping all dip switches to the opposite side, then unplugged it for 10 seconds and plugged it back in. The LED the. Displayed something other than the "CS" code. With it still powered, I reset the dip switches to original setting and unplugged again for 10 seconds. When I plugged it back in, I was able to reprogram. I'm sit sure if this is how a service tech would reset the control, but it worked for me and my mark 100 has been running fine since. Good Luck
Oct 20, 2009 | Culligan Sediment Water Filter Heavy Duty
Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Mar 25, 2009 | Dometic Rooftop RV Air Conditioner
Two ceiling fans, both remotes control the same fan
Most likely the dip switches on the remote receivers don't match (on the second fan, the one that doesn't work). While the remote dip swithes on both remotes match the working fan. You can simply reset the dip switches on the second fan receiver to match the one working remote, i.e. you don't need to have a second remote, one can work both fans as long as the codes (dip switches match). If you want you can make all the remotes the same, that way you have two remotes, or if you want them independent each remote and remote receiver must have unique codes (dip switch settings).
Nov 30, 2008 | Universal Remote Control Hampton Bay...
Dip switch positions for cmos reset please my hp compaq nx6310 is having passwaord  that i didnt put, so i want to clear the cmos
Hi.
Jun 18, 2008 | HP Compaq nx6310 Notebook
Dip switch positions for cmos reset please forgot my power-on password. can you help me with this to reset please.
Open the lap top you will find clock looking batery remove batery for 15-20 minutes then put her back close the lap top ant that is it..
May 25, 2008 | Gateway 400SD4 Notebook
Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Feb 03, 2008 | Hunter 27185 Remote Control
HP Compaq nc6320 Notebook Logo
693 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
