Question about Hobart A200 Stand Mixer
Hobart A-200 Motor Direction
I just rebuilt my a-200. I believe the motor is running backwards. It is rubbing in the back where the motor shaft protrudes and is covered by an aluminum plate. So bad that when I removed the plate and turned it on, the shaft shot out the back. If i am not mistaken it should pull itself in, not push itself out.
I followed the wiring diagram perfectly and verified its correctness.
How do I reverse the direction?
Do I swap the Hot and Neutral?
Thanks
  • 3 more comments
  • Napli1 Jun 24, 2008
    I went ahead and got a new capacitor and start switch.
    However, they have switched brands on the switch and the numbering on the diagram I have no longer lines up.
    Any thoughts?
    The old one had 1,2,3,4 the new one has 0,1,2,4,6,8
    0,1 looks to be the cap terminals and 2,4 looks to be the switch but im not sure how that lines up with the old unless 3,4 was the cap and 1,2 was the switch.
    id hate to guess and be wrong
    thanks for the help
  • Napli1 Jun 25, 2008
    The new part is from the second drawing you posted, it is part number 87714-42-1.
    The old is a Sinpak Switch from Rexnord Corporation Stearns division. It is labeled CV 16.
  • Napli1 Jun 27, 2008
    Ok, so I got the sinpak and now everything is new except the coil.
    The motor is definately running in the right direction.
    I am at a loss however because the shaft still wants to shoot out the back.
    I can hear it rubbing against the back cover!
    What am I missing. I thought that with the proper direction, the shaft would pull itself toward the front. Instead it is pushing itself out the back.
    I feel like I am missing a part or something. I have looked at the diagram time and time again but still nothing.
    Thanks again for all the help!
  • Napli1 Jun 28, 2008
    Ok, so my mixer most resembles the drawing 19357.
    Your last post didn't make much sense but it got me thinking!
    I thought resistance may force the shaft backwards so I loosened things up a bit as they were fairly tight. It doesn't shoot out the back when running anymore, but as soon as I stop it, out it goes.
    Next question, How tight should the worm gear spring be and could that be part of my problem.
    Also, could I have the clutch reversed? If I turn the planetary clockwise(proper), it rotates freely without moving the motor. If I turn the planetary counter clockwise, it turns the motor. Also, when running the motor, putting pressure on the planetary forces the motor to shoot backwards.
    Am I on to something? It seems to me that reversing the clutch would get the results I am looking for, assuming that it only slips at lower speeds.
    Thanks again, you are saving me a lot of grief! It wont go unnoticed.
    Wow, finally! It has been six months since I started and I stopped work on this project for several due to a busy schedule.
    I vaguely remember the spacer. I have been kicking it around the garage floor for months thinking it was part of my tow hitch!
    I've been doing a happy dance for the last 15 minutes!
    Thank You So Much
    Now I just need a new bowl and hook!
    Scholar:
  • 68 Answers
No, do not swap hot and N.
First, verify rotation. As the attachment shaft rotates, it should push the engagement pin into the keeper slot. Looking down on top of the mixer, the planetary should rotate clockwise.
If the unit runs backwards, does it start slow? Can you get it to run either way by giving it a push start before turning on the power? If so, your start switch is not working properly. (Which is my guess) Check your capacitor.
There is mechanical and electronic start switches. (Metal arms and a contact or a little gold rectangular metal can.)
Check it out and let me know what you find -- Mike
Posted on May 19, 2008
  • 3 more comments
  • AbsoluteServ Jun 25, 2008
    I don't know the version of mixer you actually have. On the data plate is the "ML" number. Parts for most any version of an A200 should be available. I'd need the ML and the P/N's you received to be of more help.
    http://www.hobartlink.com/extranet/extra...$File/F34656%20Rev%20B_lk.pdf pg 12
    http://www.hobartlink.com/extranet/extra...$File/F-19357%20(05-95).pdf also pg 12
  • AbsoluteServ Jun 26, 2008
    I am able to still purchase the Sinpac start switch, and I believe Hobart still stocks and sells it. p/n 271612-2
    Look at both previous links, you will see the relay you purchased AND the Sinpac start switch in both units.
    I hope I'm on the right track. Mike
  • AbsoluteServ Jun 28, 2008
    Two thoughts --
    One is common -- there is a spring washer behind the back bearing.
    The other, and often missed -- make sure the back bearing bracket is properly seated. It's not to difficult for it to hang up, and not seat fully.
    Otherwise, you'll really need to inspect the bearings and worm gear. But I really doubt your problem stems in this area.
    Note page 12. Items 11, bracket/rear housing, item 21, spacer!!!!,
    First, there is no spring washer involved here. (like I mentioned earlier) I assume, you're missing the spacer. The spacer holds the bearing in place. Without the spacer, the entire armature will thrust.
    Secondary, but to clarify what I meant earlier .... make sure Item 11 is properly seated. Because the machining is tight, it doesn't always seat proper.
    But at this point, I think you're missing the spacer, or you may be testing it without the spacer or retaining plate installed.
    Let me know -- Mike
  • AbsoluteServ Jun 29, 2008
    Glad to here it! There's some very good pricing on bowls and hooks out there. Shop around.
Need diagram for motor hobart a-200
Posted on Aug 18, 2009
What is a good source for a reasonably priced 200-240V 2.7 HP switched reluctance motor found on Hobart's HL600 mixers?
Baldor no longer manufactures that motor. Hobart would have to install a kit that includes every electrical component in the machine. Be careful if you find a used one, they have a very fragile encoder on the rear of the motor.
Aug 19, 2015 | Hobart Food Mixers
1949 hobart a200 rebuild problem
Google Hobart --utube-ebay has 300 4sale somebody might know something--waiting on the chocolate chip cookies
Aug 02, 2017 | Food Mixers
I have a hobart mixer 80 quart .The motor makes a noise and would not start. It only starts if I turn the shaft and turn the on switch at the same time
Most motors of that type have a capacitor that puts the stator out of phase with the rotor. They are capacitor start induction run motors. These also have a centrifugal switch inside near the end ot the shaft to put power to the start winding for a split second to determine the direction of turn and to increase horsepower until it is up to speed. So if it fails to start either the centrifugal switch needs cleaning (or replacement if damaged) or the capacitor needs replacing to give it its original power, or the start winding has failed from overheating. There may be a thermal cutout on the start winding that may need to be replaced if it did overheat. If the start winding burned then the motor would require rewinding or replacement.
Oct 10, 2013 | Hobart M-802 80qt Dough Bread Bakery Mixer...
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Need replacement motor for Hobart M-802 mixer
Hi Dan. Two options. The first is to call Hobart and ask about a temporary replacement mixer while your original motor is being rebuilt. They'll charge you for it, if they will do it at all. If Hobart is doing the rebuilding, they might give you a better price or a free loaner.
Second. eBay often lists hobart motors for sale, you might get lucky and find one quickly. Since you absolutely must have a working mixer for your business, you might consider having a spare motor on hand for just such an occaision.
If this solution has assisted you, please rate it. Good luck! ricardok45
May 05, 2009 | Hobart Food Mixers
A-200 mixer brush carrier orientation.
Hi. I can't help you with your first question...But I can help with your brushes problem. Unplug the mixer With the two inspection plates removed at the commutator end loosen the two screws of the brush holder which are above and below the motor bearing cover, they're the only larger screws now visible. Note the markings on the brush holder on the bottom right side where you removed the inspection plate. Rotate the brush holder to the other mark. Set the brush holder screws. Plug in the power. and start the motor. It should now be turning in the proper direction, if not, make small adjustments by loosening the set screws, and moving the brushes until it starts to your satisfaction. Be sure that the set screws are tightened when you're done. If you need further assistance, post a clarification.
I have the same spec. mixer as you do.
Mar 30, 2009 | Hobart A200 Stand Mixer
Hobart A-200 First Gear is Having Trouble
If the mixers are older the dive key shaft,spring or key are broken,if they are newer the key is sheared.Also check the nuts near the beater shaft and make sure there not too tight.
Nov 13, 2008 | Hobart A200 Stand Mixer
Motor replacement for A200
If the motor runs and when under a load the planetary stops its not the motor.You either have a sheared key or broken gear in the transmission.
Mar 22, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
1,465 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
