Question about Nintendo Wii Console
Nintendowii when the game loads ,comes up on screen,then lets you enter the game but freezes shortly after
  • 281067 May 19, 2008
    when i turn on the wii the menu screen comes up ,then i insert nintendo game disc,when i select the game on menu the wii seems to have some difficulty reeding the disc,then the screen go,s blank then comes up with an error has accerd
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Hiiiiiii
here is shivam
first i am giving video to you and tell
me is its the same prob you are facingafter that we can continue
Posted on May 19, 2008
  • 19,396 Answers
If it happens always with same game disk (or disks), then the disk is either dirty, scratched , or faulty.
If disk is dirty (sometimes you cannot even see it but they are dirty), try cleaning the disk with cold water, and rinse well with a soft cloth, ensuring not to leave wet spots or cloth hairs.
Done this try disk again.
If it is not the disk, then usually it is the lens. In this case you will have same problem with majority of your game disks.
To clean the lens start using a cleaning lens cd. This is a mild way to clean lens, often it is not enough.
The complete lens-cleaning procedure involve opening the Nintendo, and manually cleaning the lens with cotton and isopropyl alcohol.
Try the procedures above before coming back to us.
Regards
    Brigadier General:
  • 6,966 Answers
with the indulgence of the others....
This appears to be a common issue with Nintendo Wii Console. Probable causes could be the game itself (disc or dirty lens), heat related, a flash RAM in some models with the update not properly applied and/or a reformat is required. Alternately, you can try to perform a Wii System Update (Select the Update button on the right to update your Wii Console).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 19, 2008
    Hi again,
    It would appear that your problem is dirty disc as I have posted as one of the possibilities. Either that or the lens is dirty (likewise). ginko has posted a good account on how to go about disc and lens cleaning. Alternately, you can simply get hold of a CD ROM drive disc cleaner as those used in computers normally readily available from most computer shoppes. As to the game disc itself, either clean or get hold of another copy.
    Cheers.
  • 1,031 Answers
Had to disconnect the power supply cable and reconnect after sometime and see that everything's fine.
    Genius:
  • 3,422 Answers
HI,
Occasional lockups with video games can happen from time-to-time and do not necessarily indicate a need for repair or replacement. If you are experiencing frequent lockups, or a particular game always locks up in the same area, please see the information below.
Make sure you are using only licensed accessories. Unlicensed products and accessories do not undergo Nintendo's testing and evaluation process. They may not work at all with our game systems, and they may have compatibility problems with certain games or accessories.
If a game freezes while playing, usually the power, reset, and eject buttons will not respond. Try unplugging the AC Adapter from the back of the console, then check the air vents to make sure they're not being blocked.
If the information listed above did not help, please select from the links below so that we may help narrow the problem. How many games are regularly "freezing"?
Goodluck,
Please don't forget to rate or accept the solution
    Genius:
  • 1,142 Answers
Try to reset the device
  • Maanita Chadha
    Maanita Chadha May 19, 2008
    take the battery out from the gameboy and press the power button for 2 mins without the battery then reconnect the battery or the power source
    this should reset the device.
  • Maanita Chadha
    Or give me the exact model number ill give the steps to reset
My pokemon emerald game freezes when I load up my gameboy advance It does the gameboy thingy and after that screen is done a blank white screen comes up and freezes please help
take out the game and look at that open part of the game cartridge and blow inside there works for me all the time also works for ds games then put the game back in and play it ENJOY (note:that your putting the game at a little risk but the chance of ruining the game is 1 percent out of 9,000,000,000,000,000,000,000,000,000 and also that if the game doesn't load after you blow on it then blow on it again and repeat if the game doesn't work after like six times of blowing in it then put it down and let it fry because its more than likely you got spit in it and in case your wondering blowing in it clears out dust) like i said ENJOY!!!!!!!!!!!!!!!!
Oct 20, 2013 | Video Game Consoles & Games
I cant remember my pin number for parental control on my wii
  • Turn on your NintendoWii and enter the Settings Menu.
    Click on ParentalControls.
    It will ask you foryour Pin Number but just click "I Forgot".
    Now it will ask youfor the answer to a security question, just click "I Forgot" once again.
    You will now see aconfirmation code on the screen, this is what you should give to Nintendo whenyou phoneup. But we arenot going to do that.
    Head over to: http://wii.marcansoft.com/parental.psp
    Enter the confirmationcode which the Wii is showing into the box on the site.
    Make sure the date isright and click "Get Reset Code".
    You should now have an unlock code to enter in the Wii.
May 25, 2011 | Video Game Consoles & Games
How did the prince find rapanzel
Nintendo Wii Errors- How to DIY Go online to find experts that may guideyou step by step.These men online may show you how to fix your console just asan experienced repairman would fix it, but you won't even pay $5 to most ofthem! All these problems can be completelyfixed by you without the use of any external agency. Nintendo Wii: Memory Management, Gamesand Disc
1. Nintendo Wii: Data management
2. Nintendo Wii: How to Copy data to SD card
3. Nintendo Wii: SD Cards
4. Nintendo Wii: Making sure your SD card is compatible
5. Nintendo Wii: Known compatible devices Image files 6. Nintendo Wii: Known compatible devicesMovie files 7. Nintendo Wii: Error Message Disc couldnot be read/Unable to read the disc 8. Nintendo Wii: Cleaning game disc 9. Nintendo Wii: Disc ejecting automatically(including "An error has occurred eject disc") 10. Nintendo Wii: Games freeze while ingame play 11. Nintendo Wii: Message "Disc NotRecognized" 12. Nintendo Wii: Message "An ErrorHas Occurred" 13. Nintendo Wii: Disc Problems requireNintendo Service 14. Nintendo Wii: Erasing Game CubeMemory Card Data NintendoWii: Common problems 1. Nintendo Wii: Fixing time settings forloss time 2. Nintendo Wii: Delay response(display/video and audio) 3. Nintendo Wii: Can't get past"Language Select" screen 4. Nintendo Wii: Hard/Soft reset How-to 5. Nintendo Wii: Character/Cursor move ontheir own 6. Nintendo Wii: Adjusting the ParentalControl Settings of the Wii console Nintendo Wii: Error message "MessageBoard Data is full" 2. Nintendo Wii: Warning message "Becareful about posting too many messages" 3. Nintendo Wii: How do I replyto a Memo? - Why Can't I reply to a Memo? 4. Nintendo Wii: Multiple messages beingreceived from Nintendo
5. Nintendo Wii: Unable to receive emails with images attachment NintendoWii: Repairing and Disassemble Guide 1. Nintendo Wii: common error code listand description. 2. Nintendo Wii: disassemble guide 3. Nintendo Wii: Internal fan replacementguide 4. Nintendo Wii: DVD Drive playerreplacement guide 5. Nintendo Wii: Repairing DVD drive NintendoWii: Balance Board Problems 1. Nintendo Wii: How to fix problemssynchronizing the Wii fit balance board 2. Nintendo Wii: Wii Fit - TakingConsistent body test measurements Nintendo Wii: Wiimote/Remote common problems 1. Nintendo Wii: How to Sync a controller 2. Nintendo Wii: All Wii remotes will notsync with console 3. Nintendo Wii: Cursor is off center,jerky, erratic, or disappears etc. 4. Nintendo Wii: Remote buttons aresticky or stuck down. 5. Nintendo Wii: Buttons not responding 6. Nintendo Wii: No static, or cracklingnoise or no sound from Wii remote speaker 7. Nintendo Wii: No shaking,vibration or rumbling in remote 8. Nintendo Wii: Batteries drain too fast.How to increase life of your wiimote battery 9. Nintendo Wii: No cursor during game 10. Nintendo Wii: Tilt problems 11. Nintendo Wii: Message "There isno Mii save data on your Wii Remote. Format this save data?" 12. Nintendo Wii: How to repair a wiimote NintendoWii: Sensor bar Problems 1. Nintendo Wii: Disassemble guide -Sensor bar tear down 2. Nintendo Wii: Repairing a broken cableon sensor bar 3. Nintendo Wii: Adjusting thesensitivity on the sensor bar 4. Nintendo Wii: One dot during Sensitivityadjustment Nintendo Wii Power Problem 1. Nintendo Wii: No power 2. Nintendo Wii: The system plays forawhile but then shuts off on its own 3. Nintendo Wii: Power light does notturn on 4. Nintendo Wii: WiiConnect24 Settings Detailed description and fixes to all theerror codes Nintendo wiirepair guide Good luck and happygaming...
Feb 12, 2011 | Disney Tangled for Nintendo Wii
Garmin Nuvi 1350 - will not power on unless I hold power button down for the 10 second reset. At this point, the device powers on until it reaches the "loading maps" point and then shuts down.
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
  • The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
  • Market Name: On the Road
  • Serial Number (listed on the bottom of the device)
  • Question Type: Repair Information
  • Provide a short description of your problem or question: nuvi frozen on Garmin Logo
  • Full Name
  • Contact Phone Number
  • Shipping Address
Nov 11, 2010 | Garmin nuvi 1350 Car GPS Receiver
Dear;describer'my nintendowii is not going to the nintendowii shop channel.
Check that your internet connection is working, if wireless make sure the router antenna in plugged or screwed in all the way. Also your lan (local area network) security may be blocking access.
Mar 04, 2010 | Video Game Consoles & Games
Freezing on loading screen every time i enter through door
Well your disc is officially garbage because it's scratched for sure. Don't bother trying to fix your game disc. Do what I did. Go to sellitbroken.com and sell your game to them. They will give you good money for it.
Oct 07, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
Game freezes when 'ps' button is pressed
perhaps your ps3 need a firmware update...enter in sony official website and download your ps3 latest firmware...check if your ps3 hdd is ok...bad hdd´s can cause game freeze...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Freezing and not reading
Sounds like your System has become corrupted.
Have you already tried the System Restore function?
Check out my common PS3 problem and repair guide for tips and suggestions for your problem.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 21, 2009 | Sony Playstation 3 (PS3) Console
Cheats of nfs carbon in ps2
For NFS Carbon its the main menu not the "Press start" screen
Feb 10, 2008 | Sony PlayStation 2 Slimline Console
Explorist 300 problem
Try to reseting to the factory defaults: Press menu - choose preferences - press enter choose reset default - press enter choose all - yes - press enter Good luck!
Dec 31, 2005 | Magellan eXplorist 300 GPS Receiver
Nintendo Wii Console Logo
104 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
