Question about Samsung Televison & Video
My Samsung LE32R74BD HDMI input does not work. Neither does the SVideo or component inputs.
2 Suggested Answers
SOURCE: hdmi input on pioneer pdp-r04u
the r04u comes factory with hdmi DISABLED, hook up your hdmi device, and turn r04u to the hdmi  input (input 1 or input 3)  then:
To activate the HDMI terminal:
1 Press HOME MENU.
2 Press /  to select “Option”, and then press
ENTER.
3 Press /  to select “HDMI Input”, and then press
ENTER.
4 Press /  to select “Setting”, and then press
ENTER.
5 Press /  to select “Enable”, and then press
ENTER.
there you go
Posted on Aug 27, 2009
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
Can i get hd channels without an hdmi input. The TV is an HDTV
Sounds fishy to me----almost every provider uses a box that has either HDMI or Component outputs for HD--your set should if HD ready have a Component input for that also--if it only has the HDMI for that you may be out of luck. Check the owner manual to see if one of the Component inputs is HD or not.
Apr 06, 2012 | Televison & Video
I have a panasonic tv model PT-50LC13 am i able to connect a blu ray to this tv?
yes you can via component cables or rca *red yellow white* or svideo i cant recall all the inputs your tv has . if it has hdmi hdmi is the best way!
Mar 26, 2011 | Televison & Video
I cannot hook my dvd and dish network up to the tv at the same time. How can I do this? Samsung series 4+450
I assume that you are dealing with a TV with only one input of a given type. Depending on which input you are sharing, get an appropriate switch (Composite video, component video or HDMI). HDMI switches can be manual or have a remote. For a few HDMI models: http://us.startech.com/product-list/switchers . For some Component video options: http://www.svideo.com/com3.html .
How are you connecting the devices to the TV? Which inputs do you have available on the front, back, or side of the TV?
I hope this helps.
(The limit here is the TV.)
Jan 13, 2011 | Apex Digital AD-1100 DVD Player
DVD Hookup
The input buttons on the remote are shared, e.g. for component, press once for component1 and twice for component2. Same for HDMI inputs. If I remember correctly, the video button is shared by the composite input and the svideo input.
Or you can use the input button on the remote to get each input directly.
Please check what the DVD player is configured for. For 480p (PS) it can only output through component.
Dec 26, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Nov 28, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
The who input button
usually a tv that doesn't "see" video on the S-video will not even "switch" to it.  It just goes to the next Svideo, RCA etc..
Make sure your cable is not damaged. (on both ends) Does the svideo source and svideo cable work with another tv or video device?
31GT740 Manual From the Manual:   " WHO•INPUT In TV mode, press WHO•INPUT to toggle through the available Video Input channels (VID/SVID and the current channel). In SAT mode, press to select available channel lists.
Using the WHO•INPUT Button Use the WHO•INPUT button to toggle through the available input sources (VID and the current channel) and view the content from the component you have connected to the TV. 1. Press TV to place the remote in TV mode. Make sure that the content from the component is turned ON. 2. Press WHO•INPUT to tune to the available input source and view the component. 3. Press WHO•INPUT again to tune back to the channel you were previously watching.  "
James Mac
Sep 10, 2008 | GE 31GT740 31" TV
Just bought Samsung HT-tz515. how do I hook up my incoming cable television to teh system? I do not have a cable box. Can I get a splitter or other connection or do I need to get an intermediary such as...
simply buy an input selector, one with coaxle input along with rca or svideo or hdmi output then hook your cable coaxle to the input and run rca cable to the new system, very simple and works great
Aug 10, 2008 | Samsung Audio Players & Recorders
Open Questions:
Televison & Video Logo
114 people viewed this question
Henry  Thomas
Henry Thomas
