Question about Sony DAV-SC5 System
Sony DAV SC5 In home Cinema
I am trying to find some replacement speaker plugs that fit into the back of the unit. However their type is not mentioned in the manual.
  • malenka-81 Jun 16, 2008
    Hi
    Im a girl and have the same problem.... Can you tell me which bit of that label below is for the connectors? And any idea where i can get these from???
    Thanks
  • brianmlally Oct 30, 2008
    same prob ....new plugz anywhere ???
Not a very big problem. Some Samsung home theatre systems use the same connectors. I have bought ready to use cables with plugs in my country (Poland, Europe) about half a year ago and I think they are still available. It could be even possible that someone could take this cables to the USA and send them there. E-mail me at mcw.2@wp.pl
Posted on Jan 21, 2009
  • 10,594 Answers
:D its mentioned in my computer and let me tell you its part number ;)
Posted on May 29, 2008
Lost remote
check the following links for you answer
http://www.ebay.co.uk/itm/Replacement-Remote-Control-For-Sony-DAV-SC5-/271034128605?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item3f1ae498dd
http://www.ebay.co.uk/itm/Universal-Remote-Control-to-DVD-SONY-DAV-SC5-easy-to-use-TV-/110829587705?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item19cdf54cf9
http://www.ebay.co.uk/sch/i.html?_trksid=p5360.m570.l1313&_nkw=Sony+DAV-SC5&_sacat=0&_from=R40
if this does not help then no matter what you can always get a new one from SONY
ALSO PS*** check in your owners manual for info on how to program your new remote to work with your system
if you no longer have owners manual then follow this link
http://www.manualslib.com/manual/247682/Sony-Dav-Sc5-Instruction-Operation-Manual.html
Oct 20, 2012 | Sony DAV-SC5 System
Sony DAV-SC5 not playing 5.1 through the optical input from sky/blu ray
The DAV supports Dolby Digital® DTS 5.1 audio. Make sure your blueray movie has 5.1 track and is outputting to the DAV.
Jan 26, 2008 | Sony DAV-SC5 System
No sound from our Sony Wireless Home Cinema System
Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
Jan 10, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
High pitch Ringing
Does the ringing happen when listening to the radio, CD, or both?
Sep 04, 2008 | Sony DAV-SC5 System
DAV SC5 Speaker connectors...
Hi malenka-81,
I couldn't find your previous post. Can you pls let mw know the exact problem and my reply on that?
Jun 16, 2008 | Sony DAV-SC5 System
Sony DAV-SC5 System
DVD3.3V for IC206 (ZIVA5X-C1F) comes from IC906 (SI-8033JF, +3.3V REG) at Power Supply Board. :D
May 20, 2008 | Sony DAV-SC5 System
Sony dav-sc5 power problem
it is power regulator ic and must be changed.
you must check around ic pins for short capacitor or burnt resistor to complete your job
Nov 01, 2007 | Sony DAV-SC5 System
How to connect other dvd or HDMI player into dav-sc5 for amblification
If your alternate DVD player has digital audio out you can make this connection via the 'optical digital in' port on the rear of the unit which corresponds to the Video 2 function. I have done this myself because the inbuilt DVD function in the Sony unit is dead (fixed once under warranty, problem recurred about a year later, same issue as other unsolved posts on this board, DVD function hangs, system won't switch off, etc. common problem with this unit, crap product).
Oct 18, 2007 | Sony DAV-SC5 System
Sony DAV SC5 Home Theatre System - NO picture only sound when DVD / VCD played
Have you set the tv type (PAL/NTSC/Multi..) or the component type (RGB, YUV, etc.) suitable for your tv? If not, go to the main menu of your Home Theater System then check it out.
Apr 19, 2007 | Sony DAV-SC5 System
Sony DAV-SC5 System Logo
182 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
