Kitchen Ranges Logo
Posted on Sep 19, 2010
I need the part that is called the support drawer for an older model ge spectra electric range jbp80b0f2bb. I think the part number is 229c4991
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
842
Points
It looks to me like that part is not available, and they have substituted part # WB48T10030 which mounts on the back of the drawer but performs the same function
Anonymous
Level 1:
New Friend:
  • Posted on Jul 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
842
Points
How are these parts put on? i cannot find any pics online
Ge range drawer
See if this parts image helps you.
6helpful
My oven is a GE Spectra purchansed in 2000, where would I find the model number so I can replace the oven element. It is taking 2 hours to bake a rice and chicken casserole.
We're having a similar problem with our 2001 Spectra: the model and serial numbers are on a sticker on the front of the left-hand side of the drawer below the oven.
The back plastic brackets that hold the storage drawer in place as it slides open and closed have broken off what is the best way to repair this?
GOTO WWW.SEARS .COM AND CLICK ON THE PARTS DIRECT LINK UP TOP TYPE in your model number and it will search your model it should give you a schematic/parts diagram picture and you can order the pieces you need...good luck to you....
WHERE CAN i FIND MODEL NO ON A GE SPECTRA GAS STOVE
The model number is most commonly located on a nameplate along the oven door opening, or the bottom drawer opening. Some model ranges may have the model number on the back of the operator console. If you need further assistance, please let me know. I hope this helps you.
How can I tell the manufacture date on my electric spectra range?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. The following link explains how this is determined on GE products:
http://www.fixya.com/support/r3576454-determining_the_age_of_your_ge_appliance
The manufacture date is determined by the first two letters in the serial number. The first letter represents the MONTH of manufacture, while the second letter represents the YEAR.
The serial number and model number should be listed on a nameplate around the oven door opening, or lower drawer opening. Some manufacturers place the nameplate on the back of the control panel.
If you have any questions, please post back and let me know. I hope this helps you.
2helpful
Where do I find the serial number on my 30" GE range because I need a manual for the oven.
Model and serial numbers are on a tag. If you found the model number, the serial is on the same tag. The tag is usually on the back of the unit or on the side of the door, if the unit has a drawer on the bottom, check there also.
1helpful
2answers
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
1helpful
Glass cooktop
Most appliance service companies can order one for you. You can probably get one direct from GE also, but it most likely won't be any cheaper. 1-800-626-2000. (ge answer center) Make sure you have complete model number (located behind drawer front).
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
