Gestetner 3235 Mono Photocopier
Hi There,
I am having a problem with my Gestetner 3235 Mono Photocopier,
An error is displayed on the lcd which reads as follows, "Close cover of relay unit"
I would appreciate it if you could please advise me on how to identify the "relay unit". Or where i should research to find a solution.
Thanking you in advance
Mo
  • Mo Rassool May 26, 2008
    yes it is an old machine, i found that one of the door sensors wasn't aligned. Thanks for you advise.
    I have a another issue, as i photo copy, each page produces lines across the centre, i tried cleaning the inside, removing all extra toner and cleaned the top glass etc... I am wondering what should i do to remove the lines.
  • 1,326 Answers
I believe that model is fairly old.... Dosen't the control pannel have a red light showing what door or cover is opened??? Try all the doors and covers and look in the last spot you pulled a paper jam from...
Posted on May 21, 2008
  • Chris Coughlin
    Chris Coughlin May 27, 2008
    Try to stop the paper before it gets to the fixing unit (hot unit) are the lines there or do they show up after the fixing unit??? If is before the fixing unit it is most likely that it is with the drum unit, the cleaning blade or the drum it self. If it is after the fixing unit it is most likely the upper fixing roller. Good Luck
How do you reset a replace toner error on brother printer
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Apr 07, 2014 | Brother MFC-7860DW - Laser Multifunction...
I have problem model ricoh aficio 3235 error sc326
you proplem with laser unit sychro2 not detected try to clean mirrors inside laser and be carful if it's not work out change it and go to programmes and put 2-109 and 2-108
Jan 09, 2011 | Gestetner DSm635 Copier
How can I solve error code E-1 on my gestetner 2722ztd photocopier? the error occurs when I turned on the power
u need to get a full error code press star or hash key to get the rest
my gues its 101 which is exposure lamp brocken or something to do with optics
Nov 02, 2010 | Gestetner Office Equipment & Supplies
Gestetner 3235 copier speed only 35cpm it true that
replace the board and the main motor and the polygon mirror motor( not recomended)
3245 45cpm
3235 35 cpm
Oct 30, 2009 | Gestetner Office Equipment & Supplies
Photocopier comin up with error sc550 on gestetner 1302
The problem in the fusing unit.Clean and verify the heater lamp,thermistor and thernofuse continuity.
Sep 26, 2009 | Gestetner Office Equipment & Supplies
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Dove posso acquistare ricambi per gestetner 3235 aficio - napoli
You should call in to Ricoh Italy official sales ofice
The address and phones are as follow:
Italy
Ricoh Italia
Viale Martesana, 12
20090 Vimodrone (MI)
Tel: 02.91987.100
Fax: 02.91987.555
Si dovrebbe chiedere a Ricoh Italia ufficiali di vendita ofice L'indirizzo e telefono sono i seguenti:
Jan 21, 2009 | Ricoh Aficio 450 Copier
Printer stops during print job
Please check if it is giving an error and read any instruction given on the display when this happens and follows accordingly.
Jan 10, 2009 | Gestetner Copier
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    166 people viewed this question
    jasbo
    jasbo
