Question about Breville Coffee Makers & Espresso Machines
All I am getting is steam :(
Hi there
I hope you can help - when I try to make coffe all I am getting is steam - it doesnt seem to be sucking up fro the milk tank... it will make coffee but to do a whole cup would now take about 15 mins.... :(
just steam and a trickle of coffee :(
  • 3 Answers
I've read this machine produces excellent crema, probably due to the double-bottom design of the filter, which forces the coffee through 2 sieves. I've also read some other complaints about grounds becoming trapped between the 2 layers, clogging the filter. This is clearly a design flaw and NOT something you did. Some models come with a tool to unclog the wand or filters. Not sure which model you have but it seems like Breville recommends a 5 ½ -6 ½ grind in most of thier machines.
To remedy this: a good Vinegar/Water Flush & Cleaning really does wonders for the build-up and will also improve the taste/quality of your coffee.
Also, If you have a model with a pure steam function, you may want to check that it's not "selected" or "stuck" when you are "brewing". Silly as it sounds, it's another common problem with this model.
In any event~ whenever a product isn't working properly I suggest that the individual contact the manufacturer as soon as possible, as there is a strong chance they will replace the broken part or the entire product for free as long as it falls within their limited warranty time frame.
~ Good Luck and let me know how it turns out :0)
Posted on May 19, 2008
My Mr.Coffe maker percolates, steams and gets real loud. Only about 1/2 of the water fileters down to make the coffee. The rest seems to turn to steam.
A bad thermostat and may be limed up causing the steaming problem.Could also have substantial lime on t-stat probe.
Jan 21, 2011 | Bloomfield 8543 Coffee Maker
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My meile coffee machine cva620 is not froffing properly
check to see if your steam nozzle is clear unscrew tip and clean also run descaler thru to make sure steam tank is clear if still not ok steam tank thermostat may be faulty need to service machine hope this helps
Nov 05, 2009 | Coffee Makers & Espresso Machines
Bissell is not sucking up the water
Chech ut his link and this might help to solve your solutions. Hope this helps you.http://www.bissell.com/Search/FAQ.asp?FAQCategory_id=&FAQCriteria=water+wont+****&FAQSubCategory_id=&SearchMode=&SortMode=&btnSubmit.x=23&btnSubmit.y=9&FAQ_id=612
Aug 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
No water coming out
Well on a Aroma I allways test to see if its just not air in the machine.
Turn on the machine.
press the coffe button.
Then press the steamer button ( dont turn off the coffe button.)
Do it come out hot water from the steam nossle then after a while?
Then turn of the steam button, if the filter is not blocked there should now come water from the coffe outlet.
Jul 21, 2008 | Saeco Aroma Espresso Machine
Wet grounds
What you see is condensed stem comming out and no water. The pump is not sucking from the tank as ther is an air bubble in suction line. Still want coffe and don't want to clean your machine??? Flick up the lever with no group in place. Steam comes first then nothing. Pump is running and - voila - water comes as air bubble is gone. (Specially the first cup , never the following ones.) Now put back the group and brew your espresso. The machine is full of scale and neds total clean - by hand./// Olev
Jun 13, 2008 | ECM Giotto Espresso Machine
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Ventilate button does not seem to work
If you open the steam knob, can you get out any water?
Apr 22, 2008 | Gaggia Titanium Espresso Machine
Steam Knob working intermitently
run de-scale solution thru machine and flush several times
Jan 19, 2008 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
103 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Steve
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
