P4i65G not able to load windows
I'm trying to install winxp but when it the setup try load device drivers it gives error 14. i have tried to change ram,processor etc but does not seems like this mainboard working.
  • Anonymous May 20, 2008
    i have tried by reformatting, copying os by ghost but it doesn't let the windows rub at all.
  • 57 Answers
If your computer alresdy have an operating system,reformat it by changing to windoes xp.
thank you!
Posted on May 19, 2008
Asrock dual hcannel audio driver for win 7
Try the C-Media audio driver ver:Integrate003 Windows XP driver at the page for the P4i65G at the 24765074-fqlq3ztgu2xcc4onlckxgxw3-4-0.pngwebsite:
ASRock P4i65G
Sometimes the drivers for Windows XP works on Windows 7, but not all the time. If it doesn't try this:
Once downloaded, Right click on the ZIP file and choose Extract All...
Once extracted, Right click on the Setup file and choose 'Troubleshoot Compatibility'.
Your driver should then load in Compatibility Mode.
Jul 05, 2014 | Asrock P4i65G Motherboard
Hi i have been trying to install xp on Compaq presario cq56 but gives an error msg and there is no option in bios to change from sata
Are you trying to replace Windows 7? If so, I recommend you run WinXP in a virtual mode. Assuming your processor supports virtualization (I think it does) then all you need is the professional or ultimate version of Windoows 7. You can then download the necessary program and a special copy of WinXP pro. This allows you to run WinXP inside Windows 7 without the need to reboot. Look at the links below. You will need a legal version of Windows 7 pro or ultimate. I am not sure what you currently have. http://www.microsoft.com/windows/vi... http://windows.microsoft.com/en-US/...
Jun 20, 2011 | Compaq Computers & Internet
I have XP with Service pack 2. On startup I have been getting warnings on OX0000007F. Now the computer won't start. It gets the Windows XP page with the bar in it and then goes to "setup...
The issue is some of the WinXP components are not getting loaded.
Solution
When computer starts, press F8, chose option Start in Safe Mode
let the PC come to the Desktop screen
then when stable, shut down and restart.....
if the solution above does not work then you may have to re-install WinXP again. you need to use a WinXP CD and do a Repair of Windows when the install feature askes for it....
all the best
Nov 24, 2010 | Computers & Internet
Hello, First of all, I'd like to tell you that I had installed Windows 7 (clean) on my new computer. Then, I installed Fedora 13 64-bit. Eventually, I wanted to install Windows XP, so, formatted the...
Hello there kapeel_sable
First of all, why you want to install WinXP when you already have Win7 and you can just Downgrade it to WinXP..
Best Solution for this is to Recreate partition again. Start it with Win7 (dont worry Win7x is Downgrade-able to WinXP & Upgrade-able to Ultimate, Pro.) Then your Linux box.
Use quicky option compadre...
Hope that helps...
Aug 17, 2010 | Computers & Internet
Problem installing broadcom netxtreme gigabit NIC in windows server 2003 R2 standard, the driver doesn't load, error code 38
Determine Correct Driver Click Here
1: Uninstall any unwanted programs.... (make sure/Try to Clear your Hard Drive more than 50% as free)
2: Update virus software
3:Restart Computer IN Safe Mode
4: Run Virus Scan
5: Restart in Safe Mode
6: Uninstall Existing Driver Software From Device manager
7: Restart computer in normal mode
8: Start>Run> type %temp% and hit run.
9: Delete all files in this folder....
10:Restart Computer
11: DEFRAG
13: Restart COmp.
14:Install Driver
>Troubleshooting for Error 38
The error message for this error appears as: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory."
This error occurs when a previously loaded driver is preventing the new driver from loading. To fix this error follow these instructions.
  • Reboot Your PC
  • Open the Device Manager and in the device Properties box, select the General tab.
  • Properties Uninstall(Right Click Mouse) / Disable(In Property)
  • Restart PC
  • reinstall /enable
  • Once you have followed the instructions throughly, reboot your PC
Hope this make you Better Conclusion....Thanks for Using FixYa.....
Apr 21, 2010 | Computers & Internet
Just no sound.When I instll windows 7. Just no sound. Help please?
http://eudownload.ecs.com.tw/dlfileecs/driver/mb/sound/cmedia/973x/cmedia973x.zip
ENJOY!
Feb 23, 2010 | Asrock P4i65G Motherboard
I hav a laptop cq60-104tu. i want to install xp on it but it gives an error message. what should i do???
Go to the bios and change the SATA into ATA before installing window xp. You will find this option under hard disk type.
Sep 25, 2009 | Computers & Internet
USB Hardware Installation Problem
Try the following:
To fix the Error 13: Data is invalid problem, go to Start, Run... and type "REGEDT32.EXE" without the quotes to run the Registry Editor. Navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ENUM\PCI and you will see a number of keys of the form "VEN_xxxx", where xxxx are strings like "1102&DEV_0004&SUBSYS_00011103&REV_04".
Under each of these folders will be another folder with a long numerical name.
Open each folder and look for the "DeviceDesc" which matches the hardware you are trying to install.
HIGHLIGHT THE ENTRY "VEN_xxxx" for that device and select 'SECURITY'-'PERMISSIONS' FROM THE WINDOW TOP MENU and then tick "Allow" for "Full Control".
Close REGEDT32 and then continue with the installation of your device.
This wil lremove the Error 13: Data is invalid from your wnidows 2000 / 2K / XP system. Repeat this for each hardware device you get the Error 13: Data is invalid problem with.
Jan 14, 2009 | Dell Inspiron 6400 Notebook
BAD_POOL_CALLER
Try a Repair Install with your WinXP Bootable CD. If Repair option fails you will have to do a Clean Reinstall of WinXP as a last resort.
Some details:
1. Boot with your WinXP CD
2.At the "Welcome To Setup" screen, Choose the option:
To setup Windows XP now, press ENTER. DO NOT choose !!!! To repair a Windows XP installation using Recovery Console, press R. IGNORE
To quit Setup without installing Windows XP, press F3
3. Accept the License Agreement and Windows will search for existing Windows installations. 4.Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, under the Circumstances you are in the next option will be Clean install
5. I this does not work it might be your memory --download and burn to cd memtest (http://www.memtest86.com/) and test your memory for errors.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
307 people viewed this question
David Payne
David Payne
